Old 07-31-2019, 05:59 AM   #1
Riftur
Riftur's Avatar
GRAM LIGHTS 57XTREME 17X9 +40MM best tires
I really need help with which tires I should use on these rims. Currently, The tires I have are a bit small. If I was to rub a curb, the rim gets damaged because the sidewall does not fit the rim completely with the stock suspension i have. When I bought my tires, i was told a larger size would rub when turning. I currently use 245/40ZR17 91W. This is what it looks like now.
https://photos.google.com/share/AF1Q...kweHdrN3MyaWVn
Edit: To be a bit more specific, I live in South Florida so I need tires that work well in the rain.
Riftur is offline   Reply With Quote
Old 07-31-2019, 03:17 PM   #2
Riftur
Riftur's Avatar
Is there anyone who can point me in the right direction at least on where I can find the info? I searched the site but I did not find anything specific and tire stores will not mount a tire unless I buy it first. I need help!
Old 07-31-2019, 03:23 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
First of all, you shouldn't rely on your tires to protect your wheels from curbs. You should rely on your eyes and driving skills.
Second, 245/40/17 is the correct size for your wheels.
Guys like the INDY 500 for a budget tire. Also, the MPS4S is highly rated.
I LIKE TIRES!
Old 07-31-2019, 03:23 PM   #4
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Have you checkout 1010 tires? theyll give rough approximitations of how physically wide tires are with different sizes.
one issue you are running into is stretching an all season tire on wide rim set up, typically I dont have issues with a 245 on 17x9s
BUT I usually run 200tw or rcomps which naturally are wide as heck for their given "size"
try looking at a 255/40-17 the s2ki forums have alot of tires mounted on 17x9s
Clutch Dog is offline   Reply With Quote
The Following User Says Thank You to Clutch Dog For This Useful Post:
Riftur (08-01-2019)
Old 07-31-2019, 03:25 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
He has stock suspension. 255/40 is not going to fit.
I LIKE TIRES!
Clutch Dog (07-31-2019)
Old 07-31-2019, 03:28 PM   #6
Clutch Dog
well thats why you run a wide rim right?
to protect the tire from curbing?
Old 08-01-2019, 03:04 PM   #7
Riftur
Riftur's Avatar
First, Thanks for the lesson on how to drive. Second, I will look at the MPS4S, I just want a tire to fill the rim a little more. I do not like the small gap between tire and rim.
Thanks,
Old 08-01-2019, 03:06 PM   #8
Riftur
Riftur's Avatar
So unless I change my suspension, the size I currently use is as big as I can go? I just hate the little gap.
Old 08-01-2019, 03:18 PM   #9
86TOYO2k17
Drives: 2017 toyota 86
A 245, even a 225 should be able to have perfect fitment without that gap.
https://www.ft86club.com/forums/showthread.php?t=42746
That looks like either a mounting issue, or the specific tire.
Either way get a different tire. 245/40r17 is already perfect size for that wheel.
You live in Florida so zero point in an all season. Get a summer tire, either Indy 500 for a budget builder, or MPS4S for max performance. Should resolve your gap issue and increase your grip and performance.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Riftur (08-01-2019)
Old 08-01-2019, 03:23 PM   #10
xdavidx
Emperor McDuck
xdavidx's Avatar
Drives: 2019 86 GT; 2018 BMW S1000RR
Yes. This is the downside of trying to cram a wheel that is 30% wider than was intended by the manufacturer. If you don't want to deal with it, try a wheel closer to factory spec.
xdavidx is offline   Reply With Quote
Old 08-01-2019, 03:40 PM   #11
Riftur
Riftur's Avatar
Thanks for the info, thats exactly what I was looking for.
Wheel Directory: Gram Lights 57Xtreme 17x9.0 +40 L8Apex Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 71 08-05-2023 10:20 PM
Sold!! F/S:Rays Gram Lights 57Xtreme 18's TPMS+tires Amalgamo Wheels and Tires 18 08-17-2014 12:23 AM
WTB Gram Lights 57Xtreme 17x9.0 +40 ngabdala Wheels and Tires 0 06-24-2014 01:52 AM
FS (CA): Gram Lights 57Xtreme with Hankook V12 Evo Tires quasimoto Wheels and Tires 1 09-07-2013 09:43 PM
