CANADA Canada
Old 01-12-2018, 10:00 PM   #1
n0thing
Drives: Subaru BRZ
Final Drive + LSD
Any first hand experience here? I've been reading up on them, trying to justify if they are worth it, for example 1.5 way Cusco/OSG + 4.875 FD. What cost am I looking at here, from start to finish, parts and labour? Any reputable shops in GTA with experience for installation?
Thanks
n0thing is offline   Reply With Quote
Old 01-13-2018, 12:00 AM   #2
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I am running 4.88 with Cusco LSD in my automatic FRS. This was the 1st two mods I did to the car. Really been happy with the set up.
Lunatic is offline   Reply With Quote
Old 01-13-2018, 01:05 AM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It depends of what you want to achieve. If you have an AT car, it makes sense because the transmission is coming from Lexus and the gears are unreasonable long for a sports car. It is clear that this transmission was focused mainly for a highway cruiser. If you have an MT car it will give more advantage in low speeds, but it doesn't mean you will be faster in all scenarios. In other cases you'll be slower. Just to give you an example. I am following the track build of Japan's fastest NA car. They are doing this for decades and they want now to get back the track record on street tires. In a particular straight the gearing is too short and they hit the rev limiter. They have to shift to higher gear which loses time. This is happening on a S2k car. They consider now to switch the final drive from 4.3 to 4.1 or even 3.9! So, going to a 4.875 fd is not always better.
The Following User Says Thank You to nikitopo For This Useful Post:
Teseo (03-19-2024)
Old 01-13-2018, 07:25 AM   #4
scottman
scottman's Avatar
Drives: 13 mt fr-s
Nothing wrong with the stock Lsd, save cash and just buy a ring and pinion and barings etc.
Weir Performance has a good rebuild kit/ final drive price compared to Cusco or Mfactory.
scottman is offline   Reply With Quote
The Following User Says Thank You to scottman For This Useful Post:
Teseo (01-13-2018)
Old 01-16-2018, 11:31 AM   #5
n0thing
Drives: Subaru BRZ
Is the OS Given LSD compatible with the Auto factory/Revolution 4.8 FD?
Any recommended installer in GTA? How much labour should I be expecting?
Old 01-16-2018, 11:41 AM   #6
wparsons
wparsons's Avatar
Cyrious garage works put a friends shorter final drive together for him, but he removed the pumpkin from the car and re-installed it. If you're looking at total labor cost I'd add another couple hours to be safe. I'd bet it's about a day of labor to remove from the car, take apart, reassemble and then put it back in the car. Just a wild guess though.
Any FD compatible with the stock diff will work with any diff that's compatible with the stock FD, so you should be totally fine with that combination.
flickr
n0thing (01-16-2018)
Old 01-25-2018, 12:06 PM   #7
Salemate
see Dave at Newmarket Transmission.
Salemate is offline   Reply With Quote
Old 01-26-2018, 04:02 PM   #8
wparsons
wparsons's Avatar
@Trac Toy - forgot to tag you before...
flickr
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 01:49 PM
Needed: drive line shop in Houston for 4.56 final drive install - good experiences? Joesurf79 Southwest 3 03-10-2017 01:21 AM
Final drive tcroft91 Engine, Exhaust, Transmission 19 02-08-2016 12:09 PM
WTB: 4.56 Final Drive jaorocks1 Want-To-Buy Requests 0 11-04-2015 08:36 PM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 03:51 PM
