Old 10-24-2017, 10:37 AM   #1
skogs
Drives: GT86 2013
Accessing "hidden" gear in an auto
I have an auto gt86, and pretty much always drive in manual mode except when using cruise control. I keep finding myself in a position where 5th is too high and 4th is too low. In auto there is an extra gear there to fill the gap, a 4.5 gear. Is there any way to access this gear in manual mode?
via Imgflip Meme Generator
skogs is offline   Reply With Quote
Old 10-24-2017, 10:45 AM   #2
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
Uh... no there isn't?
Slammillionaire is offline   Reply With Quote
Old 10-24-2017, 10:55 AM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Lolwut?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 10-24-2017, 10:55 AM   #4
skogs
Drives: GT86 2013
At 90kph in auto at slight uphill rpm sits at 2krpm, if i put it in manual it rises to 2.5krpm in 4th gear. Changing up to 5th gives 1.6krpm.
Numbers are approx and by memory, but it is consistent.
I am prepared to be laughed at if there is something i'm missing btw:p
Old 10-24-2017, 11:02 AM   #5
steve99
Drives: FT86
You likely feeling the torque converter "lockup" most modern autos do this for fuel economy
see here
http://www.ft86club.com/forums/showthread.php?t=18868
skogs (10-25-2017)
Old 10-24-2017, 11:14 AM   #6
sIowbrz
Drives: 2015 brz
YES, PRESS THE BRAKE PEDAL AND HOLD THE SHIFT BUTTON AND SHIFT UP HALF WAY
sIowbrz is offline   Reply With Quote
Old 10-24-2017, 03:10 PM   #7
skogs
Drives: GT86 2013
OMG IT WORKED!! THE DASH SAYS "CVT MODE ENGAGED"!
Sillyness aside, thx steve99. So the tc has a different gear ratio then when its not locked..
Old 10-24-2017, 07:31 PM   #8
srt4evah
Initial G
Drives: 13 FR-S, 15 BMW 228i
I don't think that would constitute a different gear ratio, it's just allowing some slip when it's not locked, so the engine revs higher.
2013 FR-S
2015 BMW 228i
srt4evah is offline   Reply With Quote
The Following User Says Thank You to srt4evah For This Useful Post:
skogs (10-25-2017)
Old 10-26-2017, 06:36 PM   #9
rapacigila
Drives: Man
Is it possible to code to show the current auto gear you are currently on? Just like when you in manual gear mode, it shows via M1 - M5 - M8 with each shift.....
rapacigila is offline   Reply With Quote
Blinking carat "arrow" in Dashboard Gear Display 2017-BRZ BRZ First-Gen (2012+) — General Topics 14 03-29-2017 02:06 PM
2015 Series.Blue Engine "Chirp"and 2nd Gear Grind s30series Issues | Warranty | Recalls / TSB 33 09-07-2014 02:26 AM
Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings EsoBOFH DIY (Do-It-Yourself) Guides 17 04-30-2014 11:11 PM
"This repair is not covered by Subaru's limited warranty" RE: 4th gear tranny grind DoomsdayJesus Issues | Warranty | Recalls / TSB 108 04-29-2014 02:15 AM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
