Accessing "hidden" gear in an auto
I have an auto gt86, and pretty much always drive in manual mode except when using cruise control. I keep finding myself in a position where 5th is too high and 4th is too low. In auto there is an extra gear there to fill the gap, a 4.5 gear. Is there any way to access this gear in manual mode?
https://i.imgflip.com/1yca01.jpgvia Imgflip Meme Generator |
Uh... no there isn't?
Lolwut?
At 90kph in auto at slight uphill rpm sits at 2krpm, if i put it in manual it rises to 2.5krpm in 4th gear. Changing up to 5th gives 1.6krpm.
Numbers are approx and by memory, but it is consistent. I am prepared to be laughed at if there is something i'm missing btw:p |
You likely feeling the torque converter "lockup" most modern autos do this for fuel economy see here http://www.ft86club.com/forums/showthread.php?t=18868 |
YES, PRESS THE BRAKE PEDAL AND HOLD THE SHIFT BUTTON AND SHIFT UP HALF WAY |
Sillyness aside, thx steve99. So the tc has a different gear ratio then when its not locked.. |
Is it possible to code to show the current auto gear you are currently on? Just like when you in manual gear mode, it shows via M1 - M5 - M8 with each shift.....
| All times are GMT -4. The time now is 04:36 AM. |
User Alert System provided by
