| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
30k Maintenance
I'm at about 28k miles and I'm looking to do my maintenance soon. I have a list, but I'm posting it here to see if it's a good route:
I'm running a c38 SC kit with Flex Fuel, DW Injectors, DW Fuel Pump and a UEL. Here's the list and please tell me bad or good: -Motor oil:Amsoil 5w-20 (Dom Racing oil) or 5w-30 -Trans: GL-4 -Diff: 75w-90 GL-5 -Amsoil Oil Filter |
#2 |
Drives: car
I had a brake fluid flush at 30k.
| The Following User Says Thank You to radroach For This Useful Post: | strat61caster (09-27-2016) |
#3 | |
![]() Also, you might want to change the clutch/brake fluid. humfrz |
#4 |
Off Topic
The transmission fluid shoots out sideways, so plan for that.
#5 |
#6 |
Drives: 15 BRZ LTD, 05 FXT
I don't remember it being particularly dramatic...
#7 |
Senior Misanthrope
I got trans fluid on my face the first time because I didn't expect it to shoot so far. That stuff smells terrible.
#8 |
The Gunshine State
Drives: '14 BRZ Limited
Ah, the 'ol mechanic facial.
![]() Current DD: M235i |
| The Following 10 Users Say Thank You to 8RZ For This Useful Post: | ajcarson11 (09-27-2016), Crashdummy (10-13-2016), e_lunatic (08-04-2017), Kwaziekeller (09-27-2016), menikmati (09-27-2016), MrBlaze-65 (09-27-2016), MrFisty (09-27-2016), Nah (11-06-2016), Tokay444 (11-06-2016), VABeachBRZ (09-27-2016) |
#9 |
#10 |
Drives: 2014 Subaru BRZ
I'll be doing the same soon enough, got the stock filter and washer though.
#11 |
Drives: '13 FRS - STX
$/value, using street/hybrid brake pads: ATE Typ 200
| The Following User Says Thank You to strat61caster For This Useful Post: | DarkSunrise (09-27-2016) |
#12 |
Drives: 2013 Subaru BRZ Limited (Black)
I'll be honest with you -- There are terrible things that i'd rather do than be hit in the face with used transmission/gear oil. The smell is absolutely HORRID. It does come out of the transmission from the side, and will come out with a reasonable amount of force at first. You definitely want a pan to catch it... You'll see what I mean by 'horrid' soon.
I also need to do a brake fluid flush -- So i'm interested to hear responses as well. |
#13 | |
#14 |
Drives: '13 FR-S A/T - Stock
Just did my 60k maintenance at the local Toyota dealer I normally go to. They charged me $930... I'm never going there again.
$330 for parts and $660 for labor. They were kind enough to give me a slight discount. Here is what I had done: Plugs Oil, air and engine filter (Mobil 1) Diff fluid, AT fluid, brake flush I'm honestly shocked. On the phone she tells me a total of $3xx and then I see this labor charge. Outta control |
| First Car & First Maintenance. | JARE_ee | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 04-14-2016 10:23 PM |
| 50k maintenance | RickyRacer | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 13 | 07-27-2015 12:21 AM |
| For those who do their own maintenance | FR-S89 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 10-24-2014 11:03 AM |
| 25,000 Where can I go for maintenance. | laley81 | Southern California | 9 | 09-20-2013 04:00 AM |
