Old 06-10-2017, 03:13 PM   #1
drz400dude
loud clicking/knocking noise after turbo install
So I installed my works stage 2 kit and everything seemed fine. It ran for about 5 minutes, no unusual noises. Then about the time the engine temp needle hit the cold line it started making this horrible clicking/knocking noise. It almost sounds like a diesel or something. I can't quite pinpoint it, but it seems to be coming from the left side of the engine, nowhere near the turbo.
drz400dude is offline   Reply With Quote
Old 06-10-2017, 03:20 PM   #2
dostoyevsky
Drives: 2017 BRZ
Sounds normal to me
dostoyevsky is offline   Reply With Quote
Old 06-10-2017, 03:26 PM   #3
drz400dude
Originally Posted by dostoyevsky View Post
Sounds normal to me
Are you being sarcastic? Because it didn't sound like this before, and it didn't sound like this while it was warming up.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old 06-10-2017, 04:03 PM   #4
Somerandom18
Drives: 2017 manual BRZ
Sounds like mine. Like a tractor.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 06-10-2017, 04:40 PM   #5
drz400dude
Are you boosted as well? It's just weird it was as quiet as stock until it warmed up, then it got super loud. I know they are noisy little engines to begin with, but this is MUCH louder.
Old 06-10-2017, 05:08 PM   #6
Lantana frs
Drives: 13 frs red
I'd start by checking for an exhaust leak.
Lantana frs is offline   Reply With Quote
The Following User Says Thank You to Lantana frs For This Useful Post:
drz400dude (06-10-2017)
Old 06-10-2017, 05:45 PM   #7
Ethereal
Drives: 2012 VW GTI
I think it sounds cool. Very tractorish like somebody said. I like it
Ethereal is offline   Reply With Quote
Old 06-10-2017, 07:05 PM   #8
Amputechture
Drives: 2014 BRZ
^^^^what Lantana said. Every 3 months or so my turbo discharge to downpipe connection gets a leak for some reason, and it sounds very 'ticky' sounding. This is a clicky, ticky sounding motor to begin with. Aftermarket injectors will add even more tick.
Amputechture is offline   Reply With Quote
Old 06-10-2017, 07:12 PM   #9
drz400dude
I've had exhaust leaks before, and it really doesn't sound like that. I'll give it a good look over and make sure all my exhaust connections are tight.
I'm not sure if you watched the video, but its pretty loud. More of a knock than a tick. I'll make another short vid to get a comparison of when it first starts up when its cold.
Old 06-10-2017, 09:23 PM   #10
drz400dude
There was a tiny exhaust leak between the header and up pipe, but even right down next to it it wasn't that loud. I snugged that up, but it's still making the noise. I got a video of it before it started making the noise, then as it started making it.
Old 06-10-2017, 10:43 PM   #11
Lantana frs
Drives: 13 frs red
Is your car an auto? I believe they have an air pump that can get awful loud.
Old 06-11-2017, 01:48 AM   #12
Ethereal
Drives: 2012 VW GTI
Since you do not like it and want to sell pm me the price please. I am looking for an Frs or brz to buy and boost, thanks!
Old 06-11-2017, 02:54 AM   #13
Chronology
Drives: 13' Satin White Pearl BRZ
I assume you have the car on the works stage 2 flash? Pull a log from cold start and post it here.
I just saw the 2nd video that sounds off to me also, something lose physically knocking?
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 06-11-2017, 10:26 AM   #14
drz400dude
No, manual.
Idle knocking noise Kostamojen Issues | Warranty | Recalls / TSB 33 04-20-2018 02:09 PM
Rear end clicking noise after spring install Nhil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-16-2017 10:44 PM
Knocking noise from LSD after FD swap Toyota86.ir Engine, Exhaust, Transmission 15 11-08-2015 04:02 AM
Loud clicking sound when slowing down in neutral I like the tuna here Issues | Warranty | Recalls / TSB 1 05-02-2015 01:03 AM
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 10:58 PM
