Old 03-14-2017, 09:08 PM   #1
sjcurtis
Brake light on dash comes on when stopping
When I'm coming to a stop the brake light on the dash will light up and then turn off when I'm moving again. This is a 2013 BRZ and it was in a front end collision on the right side. The rotors feel like they are slightly warped and the left side inner tie rod end was bent. Everything is fixed now other then the brake light on the dash and its the same light that turns on when the parking brake is pulled up just for reference.
sjcurtis is offline   Reply With Quote
Old 03-14-2017, 09:40 PM   #2
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Have you checked your brake fluid level?
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
humfrz (03-15-2017), sjcurtis (03-14-2017)
Old 03-14-2017, 09:53 PM   #3
Bad sensor or wire. Could be tough to find.
Old 03-14-2017, 09:57 PM   #4
sjcurtis
I haven't even looked at it. I will check it when I get off work. thanks
Old 03-14-2017, 09:57 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It's covered in the owner's manual, but one of several possible causes:
https://www.subaru.com/owners/vehicl...e=2013-BRZ-DZA
https://techinfo.subaru.com/proxy/71...316DSTIS_7.pdf
Brake system warning light
• Low brake fluid
• Malfunction in the brake system
This light also comes on when the parking brake is not
released. If the light turns off after the parking brake is fully
released the system is operating normally.
Old 03-14-2017, 10:01 PM   #6
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Typically as your pads wear, the fluid level drops along with it (as long as someone hasn't been refilling your reservoir along the way), so when your pads get low, your fluid level would reach a point where it turns on your "BRAKE" light on the dash.
I'm wondering if it's a bad sensor or broken wire causing an intermittent signal, as Tcoat mentioned. What was replaced as a part of the accident repairs?
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 03-14-2017, 10:02 PM   #7
Still putting my money on a damaged sensor or wire. The accident history is a bit of a giveaway.
Old 03-14-2017, 10:08 PM   #8
sjcurtis
I will check both the front sensors and go ahead and get the rotors off and turned while I'm at it.
Old 03-14-2017, 10:27 PM   #9
sjcurtis
Ok ok ok ok I feel like a DA !!!!!!!!!!! I had to walk out to the car just to look at the fluid level and its right on the minimum level line. So I'm guessing that the fluid is going to the front of the reservoir when I am on the brakes hard enough and tripping the low level sensor like guybo said.
The Following User Says Thank You to sjcurtis For This Useful Post:
Tcoat (03-15-2017)
Old 03-15-2017, 12:24 AM   #10
Overdrive
Sittin' Sideways
Overdrive's Avatar
If that's the case make sure your brakes aren't on the verge of running out of pad surface. If they are, then replace the pads and see where the fluid level ends up before you go topping it off.
-O/D
2016 FR-S, Hot Lava
The Following User Says Thank You to Overdrive For This Useful Post:
sjcurtis (03-15-2017)
Old 03-15-2017, 12:39 AM   #11
@guybo - 1 ......
@Tcoat - 0 ...... 2nd place
The Following 4 Users Say Thank You to humfrz For This Useful Post:
guybo (03-15-2017), PandaSPUR (03-16-2017), sjcurtis (03-15-2017), Tcoat (03-15-2017)
Old 03-15-2017, 02:47 AM   #12
sjcurtis
Thanks guys I'm looking for replacement pads now or better yet a big brake kit !!!!!!!!!!!!!!!!!!!!
Old 03-15-2017, 03:03 AM   #13
........ it would be a hell of a lot cheaper just to add some brake fluid .......
Old 03-15-2017, 06:51 AM   #14
@guybo - 1 ......
Oh sure start keeping score now.
That is what I get for ignoring my own guideline of it is usually the simple thing so don't jump to the more complex based on minimal information.
As was said it now needs to be checked as to why the level is so low. Just pouring more fluid in fixes the symptom not the cause.
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 07:17 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 09:42 PM
Racing Brake BBK -- Stopping Powaaaaa // DSG Peformance Jason@DSG Brakes, Suspension, Chassis 18 08-16-2014 12:27 PM
STOPPING SPECIAL - Brake Kits, Pads, Lines, Rotors, MC Bracing - Sale @ 86Insider.com 86_Insider Brakes, Suspension, Chassis 3 09-03-2013 06:51 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 08:26 PM
