-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Brake light on dash comes on when stopping (https://www.ft86club.com/forums/showthread.php?t=116521)
sjcurtis 03-14-2017 09:08 PM
When I'm coming to a stop the brake light on the dash will light up and then turn off when I'm moving again. This is a 2013 BRZ and it was in a front end collision on the right side. The rotors feel like they are slightly warped and the left side inner tie rod end was bent. Everything is fixed now other then the brake light on the dash and its the same light that turns on when the parking brake is pulled up just for reference.
guybo 03-14-2017 09:40 PM
Have you checked your brake fluid level?
Tcoat 03-14-2017 09:53 PM
Bad sensor or wire. Could be tough to find.
sjcurtis 03-14-2017 09:57 PM
I haven't even looked at it. I will check it when I get off work. thanks
mav1178 03-14-2017 09:57 PM
It's covered in the owner's manual, but one of several possible causes:
https://www.subaru.com/owners/vehicl...e=2013-BRZ-DZA
https://techinfo.subaru.com/proxy/71...316DSTIS_7.pdf
Brake system warning light
• Low brake fluid
• Malfunction in the brake system
This light also comes on when the parking brake is not
released. If the light turns off after the parking brake is fully
released the system is operating normally.
Overdrive 03-14-2017 10:01 PM
Typically as your pads wear, the fluid level drops along with it (as long as someone hasn't been refilling your reservoir along the way), so when your pads get low, your fluid level would reach a point where it turns on your "BRAKE" light on the dash.
I'm wondering if it's a bad sensor or broken wire causing an intermittent signal, as Tcoat mentioned. What was replaced as a part of the accident repairs?
Tcoat 03-14-2017 10:02 PM
Still putting my money on a damaged sensor or wire. The accident history is a bit of a giveaway.
sjcurtis 03-14-2017 10:08 PM
I will check both the front sensors and go ahead and get the rotors off and turned while I'm at it.
sjcurtis 03-14-2017 10:27 PM
Ok ok ok ok I feel like a DA !!!!!!!!!!! I had to walk out to the car just to look at the fluid level and its right on the minimum level line. So I'm guessing that the fluid is going to the front of the reservoir when I am on the brakes hard enough and tripping the low level sensor like guybo said.
Overdrive 03-15-2017 12:24 AM
If that's the case make sure your brakes aren't on the verge of running out of pad surface. If they are, then replace the pads and see where the fluid level ends up before you go topping it off.
humfrz 03-15-2017 12:39 AM
@guybo - 1 ......:thumbsup:
@Tcoat - 0 ...... 2nd place
humfrz
sjcurtis 03-15-2017 02:47 AM
Thanks guys I'm looking for replacement pads now or better yet a big brake kit !!!!!!!!!!!!!!!!!!!!
humfrz 03-15-2017 03:03 AM
:slap: ........ it would be a hell of a lot cheaper just to add some brake fluid ....... :rolleyes:
:D
humfrz
Tcoat 03-15-2017 06:51 AM
humfrz
Oh sure start keeping score now.
That is what I get for ignoring my own guideline of it is usually the simple thing so don't jump to the more complex based on minimal information.
As was said it now needs to be checked as to why the level is so low. Just pouring more fluid in fixes the symptom not the cause.
