Old 11-01-2016, 08:23 PM   #1
hellokyles
Drives: Not running
What Parts Do You Wish Were Produced For the FR-S and BRZ?
What products would you like to see developed for both the FR-S and BRZ? Whether it be as small as custom door sills or as large as a bolt in 6 point cage (I realize these are both obtainable items), but I want to hear from everybody else!
hellokyles is offline   Reply With Quote
The Following User Says Thank You to hellokyles For This Useful Post:
go_a_way1 (11-01-2016)
Old 11-01-2016, 08:27 PM   #2
Bowen
Powered by Crickets
Bowen's Avatar
Drives: 14' SWP MT Limited BRZ
A fuel pump that doesn't chirp 😅
Sent from my Pixel using Tapatalk
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Bowen is offline   Reply With Quote
The Following 11 Users Say Thank You to Bowen For This Useful Post:
CatDaddysBBQ (11-17-2016), go_a_way1 (11-01-2016), humfrz (11-02-2016), JellyForSale (11-08-2016), KalbiCool88 (11-02-2016), Lorico (11-07-2016), Rakshaa (11-17-2016), roddy (11-17-2016), shiumai (11-02-2016), Tectoniic (11-17-2016), turtlefeeder (11-07-2016)
Old 11-01-2016, 08:29 PM   #3
radroach
Drives: car
revised throw out bearing for stock clutch
The Following 6 Users Say Thank You to radroach For This Useful Post:
CatDaddysBBQ (11-17-2016), Celica00 (11-01-2016), GoJoshGo (11-17-2016), go_a_way1 (11-01-2016), mmmcambelsoup (11-17-2016), weederr33 (11-01-2016)
Old 11-01-2016, 08:35 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I want to see some better gauge mounting options (high quality)
Luftwaffel (11-07-2016)
Old 11-01-2016, 08:46 PM   #5
Some additional ideas in this thread
"New parts do you want to see manufactured"
and
If you could see Extreme Dimensions make a new part for frs/brz what would it be?
There may be others.
and oh yea... LOUVERS!
kch (11-02-2016), Ultramaroon (11-02-2016)
Old 11-01-2016, 08:56 PM   #6
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
A steering wheel with only what I need on it...A horn button, and simple cruise control buttons...instead of the stupid buttons they've put on the 2017.
(I detest the current cruise control stalk beside the steering wheel...easily confused with the wiper stalk, and not intuitive [down to set and up to resume..odd] ).
An engine under the hood which has some low rpm torque.
Transmission and rear end gearing which will allow low rpms, running 90mph...for better gas mileage at freeway speeds.
Oh sure, this is what you really wanted to hear...
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
why? (11-07-2016)
Old 11-01-2016, 10:58 PM   #7
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
since were dreaming about things that won't be made, then this.
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
Dadhawk (11-02-2016)
Old 11-01-2016, 11:57 PM   #8
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
The Twins make me smile
The Following 2 Users Say Thank You to soulreapersteve For This Useful Post:
go_a_way1 (11-07-2016), Watch Me Run (11-02-2016)
Old 11-02-2016, 12:01 AM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
A larger capacity engine as an option.
The Following 2 Users Say Thank You to JD001 For This Useful Post:
celek (11-17-2016), go_a_way1 (11-07-2016)
Old 11-02-2016, 12:31 AM   #10
MrDinkleman
Drives: 2016 Oceanic, "base" model
A CARB-legal, PNP, 3SGE engine swap kit.
MrDinkleman is offline   Reply With Quote
Old 11-02-2016, 01:57 AM   #11
BlackCaGuy
Drives: 2013 Scion FR-S Series 10
Optional interior color and fabric choices. Also, make the convertible version.
BlackCaGuy is offline   Reply With Quote
The Following User Says Thank You to BlackCaGuy For This Useful Post:
Old 11-02-2016, 02:44 AM   #12
airjonny
airjonny's Avatar
Drives: Nissan Murano
STI trim with a 2.5 liter 240hp N/A engine that revs to the moon!
airjonny is offline   Reply With Quote
The Following User Says Thank You to airjonny For This Useful Post:
smg1138 (11-17-2016)
Old 11-02-2016, 01:25 PM   #13
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Get rid of the analog speedometer and replace it with oil temperature and pressure gauges that are calibrated in actual degrees. Put coolant temperature in degrees as well. Transmission temperature would be nice too.
Add some map lights instead of just the one overhead dome light. Add a rear dome light because you can never have enough light when you are digging through your car at night.
Get rid of the trapezoid shaped factory radio and go to a standard double DIN with analog RCA preamp outputs for an aftermarket amplifier.
Get rid of Starlink and support android/iphone mirroring.
Drill cutouts in the frame so that you can replace the spark plugs without raising the engine.
Heated steering wheel option would be nice.
sly is offline   Reply With Quote
The Following 9 Users Say Thank You to sly For This Useful Post:
Brayden_23 (11-02-2016), CatDaddysBBQ (11-17-2016), Dadhawk (11-02-2016), drew_kar (11-02-2016), KalbiCool88 (11-02-2016), roddy (11-17-2016), Teseo (11-02-2016), Watch Me Run (11-02-2016), why? (11-07-2016)
Old 11-02-2016, 01:50 PM   #14
oso_25
OH HEY NOW!!!!
oso_25's Avatar
Drives: 2013 Scion Fr-s Asphalt
Stronger Studs
oso_25 is offline   Reply With Quote
Comparison of the best ~2 liter N/A engines ever produced mit_peid FR-S / BRZ vs.... 331 07-30-2016 05:24 PM
Must See Hard Candy Shell produced from Modesta BC-04 on BMW M3 DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 06-11-2015 10:37 AM
New cars produced still suffering from first year issues? Lord09 Issues | Warranty | Recalls / TSB 30 09-22-2013 07:32 PM
Frs not being produced in auto? camelflage Scion FR-S / Toyota 86 GT86 General Forum 70 04-17-2013 09:50 AM
