Old 06-05-2017, 10:16 AM   #1
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
@MarshallBRZ06 LS3 525 Swap/Build
LS3 525 6.2L install by Weapons Grade Performance on 2013 Subaru BRZ. A great build, runs beautifully and it all fits under the hood in a nice tight package. Highly recommend contacting WGP to get some questions answered about having the build done. Was so much help and suffered through all my questions with a smile!
I am here to answer questions for those who are interested in getting a swap done as well as anything they would like to know or see about the car.
Here is a list of things done to the car:
-LS3 525 6.2L crate engine (new)
-SIKKY cold air intake
-SIKKY shifter relocation kit
-SIKKY engine mounts (I believe)
-T56 Magnum 6 speed trans.
-Full Blown Motorsports radiator
-FBM slim fans
-Custom built aluminum drive shaft to length
-Driveshaft Shop 600HP rear axles
-stand alone ECU communicating with OEM ECU for dash function
-DW fuel pump
-Optima Red top battery
-Magna Flow cat back (custom front pipe aligns with OEM location)
-18x9 Tenzo-R rims with 245/40/18 pilot super sports
-Skunk2 Coil overs with adjustable camber
-Stance adjustable lower control arms
-Cusco strut tower bar
-raceseng shift knob with VMS racing shift handle
-MOMO racing drifting deep dish steering wheel
-NRG steering wheel hub adapter
-VENT pod with innovate motorsports AFR gauge
-Dual vent gauge pod cluster with AEM oil pressure and AEM coolant temp
-WeatherTech custom fit matts with BRZ logo
-Blacked out inner headlights
-Blacked out tail lights
-Perrin hand brake release button
-LED Million Colour glow kit (interior)
-Weathertech floor mats with BRZ emblem
That's all I can think of right now. Pending items awaiting install is Rocket Bunny V3 Pandem kit. Wheels are being built (forgestar m14 gloss black), and a full body vinyl wrap, ideas are welcome as I have yet to decide how the car will be vinyl wrapped. There are some pictures of the car on instagram @Marshallbrz06 and I will try to load up some pictures later on.
Feel free to ask me anything!
69Marshall69 is offline   Reply With Quote
Old 06-05-2017, 10:22 AM   #2
69Marshall69
Image of swap
Old 06-05-2017, 11:18 AM   #3
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Looks good, what standalone ECU? Cause that looks like the GM ECU to me.
Old 06-05-2017, 11:53 AM   #4
69Marshall69
Ill have to double check, but there a programmer located inside the cabin on the passenger side. What may be displayed in the engine bay is OEM
Old 06-05-2017, 11:55 AM   #5
DustinS
DustinS's Avatar
Okay. Sounds like the MRS Can Bus device. Same thing I am running. Great little device. Excited to see more of your build.
The Following User Says Thank You to DustinS For This Useful Post:
69Marshall69 (06-05-2017)
Old 06-05-2017, 11:55 AM   #6
69Marshall69
you have a link of your build?
Old 06-05-2017, 03:18 PM   #7
BDKane01
BDKane01's Avatar
Drives: 2016 Subaru BRZ Limited CWP MT
Question, are you unable to run a front sway bar with the swap?
Hindsight is 20/20
BDKane01 is offline   Reply With Quote
Old 06-06-2017, 09:04 AM   #8
69Marshall69
Still running it. Custom oil pan clears it as well as the over pipes, although it is TIGHT in there
Old 06-06-2017, 11:21 AM   #9
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Cool! Have any videos of it? Do you have AC?
ILLSMOQ is offline   Reply With Quote
Old 06-06-2017, 12:06 PM   #10
DustinS
DustinS's Avatar
Does your fuel gauge work correctly?
Old 06-06-2017, 12:06 PM   #11
69Marshall69
I haven't got videos yet but ill get it asap and post it on instragram. There is AC hookup but I don't have the compressor installed. I will hopefully soon as it gets sweaty inside
Old 06-06-2017, 12:17 PM   #12
69Marshall69
it does in the sense of telling me when im full half way and empty haha there are updates for my programing chip to allow more increments. That will be fixed further. The only thing that doesn't properly function is the coolant temp Gauge, again there is an update coming my way
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Build Happening soon.....2jz Swap JK21 Engine Swaps 85 04-16-2019 08:21 PM
Ferrari 458 Swap - Ryan Tuerck / Gumout Build MarkR171 Engine Swaps 49 09-22-2017 06:39 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Any active 2JZ swap build threads? JordanWho Engine Swaps 100 02-15-2015 07:31 AM
