Old 08-24-2016, 01:27 AM   #1
SlydwinderFT86
Drives: 2015 scion frs
Catless header noise reduction
Hey folks,
Has anyone found a good way to minimize the amount of noise from the catless head with an exhaust?
SlydwinderFT86 is offline   Reply With Quote
Old 08-24-2016, 01:43 AM   #2
renfield90
The Stig's German cousin
Drive slow.
Old 08-24-2016, 01:46 AM   #3
SlydwinderFT86
That a given my commute is filled with lots of traffic.
I'm thinking of putting a muffler on the own front pipe to bring the noise down.
Any suggestions or alternatives?
Old 08-24-2016, 02:52 AM   #4
What type/kind of muffler do you have on it now..??
Old 08-24-2016, 09:13 AM   #5
FirestormFRS
If you're still on the stock exhaust from the header back.....it won't get much quieter than it already is.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
everythingsablur (08-24-2016)
Old 08-24-2016, 11:36 AM   #6
SlydwinderFT86
Invidia n1
Old 08-24-2016, 12:11 PM   #7
kev60625
Drives: 2013 WRB Subaru BRZ
Invidia n1
There's your problem, the n1 is insanely loud when you switch out other exhaust parts.
Should've researched more before buying the n1
kev60625 is offline   Reply With Quote
The Following User Says Thank You to kev60625 For This Useful Post:
kch (08-24-2016)
Old 08-24-2016, 12:24 PM   #8
wootwoot
Drives: FRS
A cat....
Old 08-24-2016, 12:33 PM   #9
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
the stock unit should do the trick..... /smfh
driftartist is offline   Reply With Quote
Old 08-24-2016, 01:22 PM   #10
kch
Senior Misanthrope
kch's Avatar
N1 + catless header = bad time. You need a different catback. Stock works okay, but sounds a little farty with a catless header. I use the perrin 2.5" resonated and it's pretty reasonable.
Old 08-24-2016, 01:25 PM   #11
SlydwinderFT86
I hate to even consider this, but I was thinking to putting the flowmaster hush power muffler on the front pipe replacing the second cat.
Old 08-24-2016, 02:37 PM   #12
renfield90
I have a catless header and a muffler delete. I don't see how any kind of muffler is too loud, but there's always the stock unit or you can keep the revs under 3.5k.
Or you can switch to a catted header. It's less than a 5hp difference and far more emissions-friendly. I would have done this myself if I wasn't building the car for competition, especially if noise was a concern.
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 08:13 PM
Catted vs resonated front pipe noise reduction difference raven1231 Engine, Exhaust, Transmission 11 03-30-2017 11:20 AM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
making the exhaust noise tolerable at WOT and being catless. BRZPDX Engine, Exhaust, Transmission 24 01-27-2014 01:20 PM
