Old 07-22-2017, 09:52 PM   #1
adjusts
adjusts's Avatar
Drives: 86
Thump sound when blipping/stabbing throttle (Supercharged)
Hey all,
I have a JRSC C30 kit installed on my 2013 FRS, tuned with ecutek + delicious.
After loading my base tune, I have noticed that whenever I downshift (rev match) or blip the throttle, I hear a thumping sound coming from ahead of me.
This occurrence only happens when I blip the throttle. The sound is not an exhaust pop, as it is not a sharp sound. Instead, it is a muted, toned down knocking sound.
The thump is too faint to be recorded on video. This noise happens regardless of the gear (idle, first, second, etc). All the sounds are the same, and it is hard to diagnose what exactly it is.
Despite having received several revision tunes, the sound still persists. I have checked all my hoses, and there seems to be no vacuum leaks or leaks in general. At the same time, my throttle response has become more sluggish ever since installing the kit and receiving the tune.
Anyone else have this issue? I did not have this noise when I was NA, and the issue only arose once the kit and tune were on the car.
Note: I do not experience this sound when the throttle application is gradual, rather than abrupt. The noise seems to be coming from ahead of me in the engine bay, I also hear a vacuum sound simultaneously. Could this just be the intake?
More notes: narrowed down where the sound is coming from. Seems to be coming from the throttle body tube compressing upon sudden load. I have attached a video showing what I mean
Any idea if this is normal? The hoses are completely clamped down and seated properly, yet this still occurs.
adjusts is offline   Reply With Quote
Old 07-22-2017, 09:54 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Well, think about components that are "underneath you" and troubleshoot from there.
Old 07-22-2017, 10:39 PM   #3
adjusts
adjusts's Avatar
Drives: 86
Edit for words: just attained a video showcasing what's going on. Any idea how this can be fixed? Everything's tightened down.
Old 07-22-2017, 11:52 PM   #4
Summerwolf
Panda Trueno
Summerwolf's Avatar
Are you talking about the sudden air induction noise?
Old 07-23-2017, 12:16 AM   #5
adjusts
adjusts's Avatar
Drives: 86
I'm talking about the compression of the inlet tube. Not sure if its somtehing to be expected or if its irregular.
Old 07-23-2017, 01:52 AM   #6
OND
OND's Avatar
Drives: 2023 BRZ
What the heeell i've never seen anything like that but all my aftermarket intakes had aluminum piping. I hope thats a defective tube and not the real deal.
Id contact JR about it for sure.
OND is offline   Reply With Quote
The Following User Says Thank You to OND For This Useful Post:
adjusts (07-23-2017)
Old 07-23-2017, 01:08 PM   #7
Cal3000
Drives: Panda FR-S
Interesting, I have the same issue. Similar sound. Only difference is that I have an aluminum inlet tube. But sometimes when I blip the throttle, it would make that noise. I know when I would cold start my car on e85, it would make that similar noise also. I data logged on start up one time and it didn't detect knock. I think my issue is different as yours seems to be strictly with air pressure.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
Old 07-23-2017, 02:56 PM   #8
adjusts
adjusts's Avatar
Drives: 86
Interesting. Do you find that your throttle response has become more sluggish since this issue arose for you? Is throttle delayed at all? This seems to be an issue with mine.
Old 07-24-2017, 01:04 AM   #9
ryoma
ryoma's Avatar
sorry that I have nothing useful to say, but DAMN that looks crazy lol
Old 07-24-2017, 04:42 PM   #10
adjusts
adjusts's Avatar
Drives: 86
some updates:
Getting a variety of answers: some say its the silicon inlet hose and it must be replaced with an aluminum one.
Jackson racing is informing me that its the bypass valve, but everything seems to be hooked up properly and clamped down. Anyone else have this problem with the car?
My tuner says its a mechanical issue, but there doesnt seem to be any leaks/issues.
Old 07-24-2017, 05:34 PM   #11
OND
OND's Avatar
Drives: 2023 BRZ
I'd definitely listen to JR instead of some random dudes on a forum (like me)
It makes sense that a stuck bypass valve would cause the "vacuum shock" in the intake hose. There are multiple threads online that mention simple tests to see if the valve is working, which might help you.
Throwout bearing? Noise when blipping the throttle with the clutch in... VVT4ME Issues | Warranty | Recalls / TSB 6 04-23-2017 04:55 AM
Thump sound from Borla Exhaust? blightmike Engine, Exhaust, Transmission 8 02-28-2016 01:08 PM
Is stabbing the throttle bad? Astroboy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 06-18-2015 02:11 PM
Ways for faster revving when blipping the throttle?? glamcem Tracking / Autocross / HPDE / Drifting 41 06-19-2014 02:16 AM
Clicking when blipping throttle Colpup Issues | Warranty | Recalls / TSB 7 06-09-2014 11:55 PM
