Old 01-27-2016, 05:00 PM   #1
JD001
JD001's Avatar
Drives: Subaru BRZ
Rust!!!
March 2016 Evo magazine has published a buying guide for the twins. It covers the usual but shock horror it talks about rusting quarter-light pillars on both front windows. I have not seen any threads talking about rust, is this real?
Old 01-27-2016, 05:02 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Oh noes!!
*runs outside and checks car*
*stops and realizes that MisterSheep lives in California and doesn't have to worry about such thing*
Lets ask @go_a_way1 he lives in Canada.
Instagram: trevor.parque
The Following 3 Users Say Thank You to MisterSheep For This Useful Post:
go_a_way1 (01-27-2016), JD001 (01-27-2016), strat61caster (01-28-2016)
Old 01-27-2016, 05:03 PM   #3
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Oh noes!!
LMAO I guess since you posted so do I.
I live in canada with salty roads, rust free 3 winters so far
Old 01-27-2016, 05:14 PM   #4
Yes it is real and no it is not near as bad as it sounds. There are a couple of threads on it. I will see if I can find them.
Like so many issues it seemed to be restricted to some of the very early 13s.
http://www.ft86club.com/forums/showthread.php?t=63579
MisterSheep (01-27-2016), strat61caster (01-28-2016)
Old 01-27-2016, 05:19 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Phew!!! I was already doing man maths to swap it for a dare I say it.. . M2..
Old 01-27-2016, 05:21 PM   #6
MisterSheep
Killed Scion
Keep the 86. A little bit of rust shouldnt scare you off. Especially when the first model was released maybe 3-4 years ago.
JD001 (01-27-2016)
Old 01-27-2016, 05:21 PM   #7
Nah you should be good. Can't find the other thread but if I recall it is one of those issues that you either get quickly or not at all.
JD001 (01-27-2016)
Old 01-27-2016, 05:26 PM   #8
df.dima
Drives: FR-S and Mazda 3 Sky
The good thing about the rust in that spot, if it happens, you can actually swap out the part. If you had it elsewhere on a body, like rear fenders, you'd be in for a world of pain, grinding and re-painting.
df.dima is offline   Reply With Quote
The Following User Says Thank You to df.dima For This Useful Post:
JD001 (01-27-2016)
Old 01-27-2016, 05:43 PM   #9
So far after one winter of salt piles and a wet summer I have no rust other than bolts and fasteners that are not treated and you expect to rust. There is even a big rock chip on my front fender that I purposefully left untouched just to see that is still rust free. I am very optimistic at this point.
soulreapersteve (01-28-2016)
Old 01-27-2016, 05:57 PM   #10
....................There is even a big rock chip on my front fender that I purposefully left untouched just to see that is still rust free. I am very optimistic at this point.
.....Tcoat checks later today........
OP, I wouldn't worry about it .... if I recall proper, it was no more than a bit of "discoloration" at the base of the window strip.
Easily taken care of with a toothbrush and a bit of rubbing compound.
go_a_way1 (01-27-2016), Tcoat (01-27-2016)
Old 01-27-2016, 06:08 PM   #11
Ummmm not exactly.
It does however seem to be very, very rare and restricted to a certain run of cars.
Old 01-27-2016, 06:50 PM   #12
Ummmm not exactly.
OK, OK ...... a brass brush, a strip of fine grained sandpaper and some touch up paint .......
Old 01-27-2016, 07:12 PM   #13
roddy
roddy's Avatar
Drives: '13 Ultramarine
That's ugly. As stated above though, if it happens, the part can be easily swapped out. My car is an early production (April 2012) vehicle, and it is on it's 4th salty Southern Ontario winter...I don't have that problem.
Old 01-27-2016, 07:16 PM   #14
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
My BRZ was assembled June 2012 which makes it an early model and has no such rust despite 3 years of daily driving on salted and sanded roads.
Edit: I will also note that it has never been rust proofed.
Lynxis is offline   Reply With Quote
brz rust chenshuo BRZ First-Gen (2012+) — General Topics 30 02-26-2014 11:32 PM
Exhaust Rust aghuman Issues | Warranty | Recalls / TSB 20 01-06-2014 01:20 PM
Lug Nut Rust Wesley Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 17 04-14-2013 08:06 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 05:15 PM
Rust already? Fugazi BRZ First-Gen (2012+) — General Topics 9 08-26-2012 03:36 PM
