Old 01-21-2016, 11:25 PM   #1
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
Sound different driving before car is warmed up?
Hello,
I've always wondered if everyone else's brz sounds slightly strange when driving before it is fully warmed up.
I hear a whiny noise when I accelerate, almost like a mini supercharger...most likely source is the belts.
The exhaust note is a lot more raspy and dull sounding compared to the usual deeper note rumble (I have UEL)
But once the car is warmed up, all of these disappear. What is the cause of this?
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 01-22-2016, 12:03 AM   #2
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
Originally Posted by ray7792 View Post
Hello,
The predominant cause of the engine sound and resultant exhaust note prior to the engine reaching operating temperature is negative valve overlap combined with an initial high idle. Simply put, NVO helps warm the primary catalytic converter, lowering tailpipe emissions. See this patent for more information: http://www.google.com/patents/US6394051
theadmiral976 is offline   Reply With Quote
The Following 2 Users Say Thank You to theadmiral976 For This Useful Post:
86kahl (01-22-2016), SmartedPanda (01-22-2016)
Old 01-23-2016, 12:29 AM   #3
ray7792
ray7792's Avatar
Thanks for taking the time to reply.
Cool, didn't know google had a patent database haha.
I believe NVO is the negative ignition timing that can be found on the ignition timing post start timing with Romraider. But once the car starts to more, it switches to the primary base tables which does not seem to be affected by temperate. But i didn't consider until now that there are most likely a bunch of other timings based on temperate that would change the resulting exhaust note.
'13 BRZ (sold)
'17 STI
Slight beeping sound while driving Furinax Issues | Warranty | Recalls / TSB 2 10-31-2014 06:19 PM
Knocking sound in wheels during driving WallsAndFoundations Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-28-2014 01:45 AM
Can't get into any gear from a stop once car is warmed up Pneub Engine, Exhaust, Transmission 34 04-23-2014 12:50 PM
Can't get into any gear from a stop once car is warmed up Pneub Issues | Warranty | Recalls / TSB 5 04-04-2014 03:32 AM
Exhaust Noise that goes away after warmed up FastLane1000 Engine, Exhaust, Transmission 10 08-15-2013 11:06 PM
