Drives: FRS
Double sided tape
Does anyone have any idea if Toyota sells the double sided tape they use on the TRD body kit and spoiler? The stuff I pulled off the spoiler, for example, was really thick and it's hard to source. I also don't know the exact thickness I need. If Toyota stocks a particular size that would help. Ideas?
#2 |
Junior
Drives: a car
3M tape, unless toyota's is already rebranded 3M.
| The Following 2 Users Say Thank You to cdrazic93 For This Useful Post: | DieselDog (07-11-2015), Packofcrows (07-08-2015) |
#3 |
Drives: FRS
I know, but it isn't standard double sided tape. It's more like foam tape. And it's fairly thick.
#4 |
Drives: (formerly) 2013 Raven FR-S
I would still recommend 3M Automotive Acrylic Plus tape. I never see it in stores though; I usually just see the "Super Strength Molding" tape which is not as good as the Acrylic Plus.
#5 |
Drives: FRS
That's exactly what I ordered but it's too thin. The oem white tape is over 1/4" I think.
#6 |
Maybe try using two layers?
#7 |
Drives: FRS
Anyone else? Two layers isn't thick enough.....
#8 |
Drives: FRS
One last bump as a last ditch effort. I've searched for hours on the net, made all sorts of calls, and can't find anything thick enough. I need a minimum of 1/4" thick. Anyone?
#9 | |
Time Traveller
Start at findtape.com Here: http://www.findtape.com/category/foa...b&holiday=none and/or Check their foam tape comparison matrix http://www.findtape.com/shop/compari...LH0Ej3l&cid=23 And if you can't find it from one of those links, call their number 1-800-806-7580 Lastly... if you end up using 3M automotive tape, make sure to use 3M 4298 adhesion promoter. It will make certain that your parts are going nowhere. It's also very cheap on the same website in swabs or a larger bottle container. http://www.findtape.com/product605/3...sion+Promoter+[Bottle] Last edited by DAEMANO; 07-13-2015 at 05:48 PM. |
#10 |
Drives: brz
use 3 layers ¯\_(ツ)_/¯
#11 |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#12 |
Drives: 2013 BRZ black
Google 3M VHB tape. You can get it in as thick as .090" Which is really fucking thick for tape. .250" thick tape probably wouldnt do well holding anything together. Thats like window gasket sealer thick.
#13 |
Drives: FRS
.250 is how thick the stock stuff is.....
| Two-Sided tape for Aero parts | Freude am Fahren | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 12-15-2017 06:39 AM |
| Double sided tape for spoilers? | MileHighBRZ | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 05-20-2015 01:47 AM |
| which 3m tape is this? | mokinbird87 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-29-2013 10:12 PM |
| 3M double sided tape for FR-S emblem | denverizzles | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-20-2012 12:03 AM |
