Drives: Fr-s trd
Jackson racing 12 psi pulley
Hello,
Currently I have the standard Jackson racing supercharger, Jackson oil cooler, good headers, front pipe, flex fuel kit for E85, upgraded fuel injectors, etc. With an upgraded fuel pump, and a proper tune, how safe on your engine is the high boost pulley that Jackson racing makes? I understand I can't have an exact answer, and there is no direct science to it, but with an educated guess, how many miles can the car last with moderate driving? (No track days, rare red lining, usually driven at the speed limit.) Also, assume it's a proper tune done by delicious. Thanks!! |
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Anywhere from 10-500,000 miles. Just keep in mind more power = more chance for somthing to go wrong. Is it worth the risk to you? |
#3 |
Drives: 2013 Raven FR-S
there are guys that have blown up on the dyno with FI. and like go a way said, guys running ten of thousands of miles. obviously the tune is probably the most important factor but a lot of the luck comes down to a gamble. I'm sure the factors of no track days and/or redlining will help give you better odds.
| The Following User Says Thank You to cdq85 For This Useful Post: | go_a_way1 (12-12-2015) |
#4 |
Dismember
Drives: 2013 Red Scion FR-S
Motors have blown with Delicious tunes, too. As long as you've budgeted for a new motor, go for it.
| The Following User Says Thank You to EAGLE5 For This Useful Post: | go_a_way1 (12-12-2015) |
#5 |
Drives: Fr-s trd
Thanks for the replies. How about this... Any documented failure cases using the pulley?
#6 | |
Drives: Scion FR-S
i could fully depress the stock valve springs with my fingers! setup: hks gt sc hks oil cooler fic 660 injectors dw65c pump skunk 2 I beam connecting rods titanium valve springs cosworth head gaskets lowering compression 0.8-1.0 ft86speedfactory headers - no cat act 6 puck clutch LW flywheel e-85 95mm pulley no restrictor trd catch can. Last edited by Andew727; 12-15-2015 at 05:14 PM. |
#7 |
Running the high boost pulley with a lower redline is easier on your engine than running the normally pulley with a normal redline.
If you're never redlining, I wouldn't expect engine life to be shortened. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Deep Six (12-15-2015), TouchMyHonda (08-18-2016) |
| Jackson Racing SC Kit - C30-94 Rotrex Supercharger High Boost Pulley Release | CounterSpace Garage | Forced Induction | 313 | 03-08-2021 08:39 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing BRZ | Parikh1234 | Member's Car Journals | 31 | 12-29-2015 10:26 AM |
| Jackson Racing Kit AT6 | CladMonitor | Forced Induction | 26 | 06-27-2014 11:27 PM |
| Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 03:29 PM |
