Old 04-25-2018, 04:34 AM   #1
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Request: resonated straightpipe
Does anyone run a resonated catback with catless/unresonated everything else (hd/op/fp) so I can hear what it sounds like? Basically almost full straightpipe except a resonated CBE with the muffler.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 04-25-2018, 12:45 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
That's not a straight pipe if it has a resonator and a muffler.
I can tell you from experience, a fully catless setup with just one resonator is loud and raspy like no other while NA. If you're turboed, it's a bit more bearable but still super loud.
tyler_win_photo is offline   Reply With Quote
Old 04-25-2018, 12:48 PM   #3
Timmy_Jones
Spun
Drives: 17' Focus RS
The rasp and awful noises are NOT worth it, if you are full catless. I have a single hi-flow cat in my front pipe with a resonator and muffler and there is still rasp.
Timmy_Jones is offline   Reply With Quote
Old 04-25-2018, 12:50 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
A video from a set-up like this will be deceiving more then likely. Rasp and the tin-can/high pitched tone don't correlate well to most audio recording set-ups.
Old 04-25-2018, 12:52 PM   #5
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Depending on how the exhaust is designed, rasp can be eliminated. Resonated front pipes tend to have small tube diameters...sometimes smaller than OEM.
CounterSpace Garage is offline   Reply With Quote
Old 04-25-2018, 01:02 PM   #6
Lakitu
Lakitu's Avatar
Ok thanks, was just trying to see if I could be cheap...test pipes are $100 cheaper than the catted and $200 cheaper than catted+resonated. Looks like I'm definitely going to get the catted front pipe for peace of mind. Thanks guys
Old 04-25-2018, 01:09 PM   #7
Timmy_Jones
Spun
Agreed, I went with a 2.5" OD Front pipe and hi-flow cat and still have some rasp. I think the Invidia/HKS are like 2.3" and those do rasp, as well.
Would you care to send me over your big diameter front pipe? Happy to test for rasp!
Old 04-25-2018, 01:23 PM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It will make your ears bleed. Badly.
The below clips aren't of straight pipe front pipe, but it will be about the same tone but louder. The unknown part is what exhaust, because every different design in resonator & muffler size will make the final sound different.
Tomei UEL + Fujitsubo front pipe + Blitz Nur-Spec R (straight through exhaust design)
[ame="https://www.youtube.com/watch?v=iItifvYzrDs"]Blitz Nur-Spec R exhaust w/ Tomei UEL header + Fujitsubo front pipe Scion FRS Subaru BRZ sound clip - YouTube[/ame]
Same as above except with Blitz Nur-Spec VSR (baffle design):
[ame="https://www.youtube.com/watch?v=sWxvQXjjgaQ"]Blitz Nur-Spec VS/VSR exhaust + Tomei UEL header/overpipe w/ Fujitsubo FP Scion FRS Subaru BRZ - YouTube[/ame]
You can clearly hear "rattle" with baffle types, this is the drawback of running full catless and mixing different types and sizes on resonators in the exhaust stream.
I should note, I ran this last setup at COTA, the car was quite tame sound-wise at WOT. The "annoying" part is the rattle, you can hear it in the car if the rear seats are down.
Old 04-25-2018, 01:29 PM   #9
mav1178
mav1178's Avatar
Catted does not mean it's quieter.
Berk HFC front pipe is louder than stock by almost 4db with stock everything else.
Old 04-25-2018, 03:56 PM   #10
Lakitu
Lakitu's Avatar
Wait.. Some months ago people here said catted is quieter than no cat, and in my mind that made sense since the sound has to travel through a material, and I based my entire setup and everything off of that. But it's incorrect?
Please help.
Old 04-25-2018, 03:59 PM   #11
Lakitu
Lakitu's Avatar
The first one doesn't sound that bad to me. The 2nd has a split second of ear-piercing rasp. Do not want.
Old 04-25-2018, 04:00 PM   #12
Timmy_Jones
Spun
Please help.
All things equal, a catted setup will be quieter than a catless. The Berk setup probably has a hi-flow cat, thinner material and may be a bit wider? So yes, it would absolutely be louder than stock.
Old 04-25-2018, 04:00 PM   #13
Lakitu
Lakitu's Avatar
wtf is the point of a resonated CBE if it won't reduce the unwanted frequencies. Did I just fuck up my whole exhaust setup? lol
Old 04-25-2018, 04:07 PM   #14
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
I'm not following. A high flow cat is louder than a stock cat, sure. Are there uncatted front pipes that have a db increase of less than 4db? I don't think I've looked at the db increases for front pipes (if there even are many recorded), honestly curious.
Horrid_Funk is offline   Reply With Quote
Nvidia catless resonated or non resonated front pipe (q300 owners) ArtisticMaru Engine, Exhaust, Transmission 4 05-12-2016 05:44 PM
Catted UEL Header and Catless resonated/dual resonated front pipe? deuncos Engine, Exhaust, Transmission 3 04-23-2016 02:30 PM
Downpipe / Straightpipe Difference? mystic Southern California 18 10-23-2014 01:40 PM
Nameless Overpipe/Front Pipe VIDEOS RESONATED OR NON-RESONATED POST HERE !! ScionFR-S Engine, Exhaust, Transmission 20 05-27-2014 05:36 AM
Anyone straightpipe vids yet? Bounce Engine, Exhaust, Transmission 8 06-11-2012 05:39 PM
