Old 10-21-2013, 02:07 PM   #1
Admired
Drives: 2013 Scion FRS
Wideband
So when I get the FA20Club turbo I assume I will need a wideband gauge and sensor, is there any other gauges that are necessary for turbo operation? What wideband gauge/sensor is a good one to get?
Thanks
Admired is offline   Reply With Quote
Old 10-21-2013, 02:09 PM   #2
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
Thanks
I use the AEM failsafe for wideband and boost. I also use the Innovate MTX-D for oil temp/pressure.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
The Following 3 Users Say Thank You to bgibbsunc For This Useful Post:
20valvewynn83 (10-21-2013), SirBrass (11-25-2013), Sportsguy83 (10-21-2013)
Old 10-21-2013, 02:11 PM   #3
jamesm
i use an innovate ot-2 with a wideband (lc1) plugged into the MTS chain. i've found this to be the most convenient way to log. i also use a variety of programs over j2534 to log obd2 params with a tactrix cable (which is crazy fast, btw).
it's worth nothing that we will very soon be able to use the romraider logger with extended parameters, which is fantastic.
Old 10-21-2013, 02:17 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Me 2
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ftc~brz (01-22-2014)
Old 10-21-2013, 02:50 PM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
AFR and boost are mandatory in my mind. As mentioned the AEM Failsafe is the best most affordable option to combine both and have automatic datalogging capabilities of 3 hours with RPM input.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Nomed Alucard (02-26-2014), Sportsguy83 (10-21-2013)
Old 10-21-2013, 02:52 PM   #6
Admired
Sounds good I will go with this option. So how important are readings such as oil temp and pressure, fuel pressure, cooling water temp, etc.?
Old 10-21-2013, 02:55 PM   #7
King Tut
NASA SpecE30 Racer
King Tut's Avatar
The factory water temp gauge is accurate enough. I would put oil pressure as the next most important as it may alert you in time to prevent a failure should one of your turbo oil feed or drain lines decide to remove itself, but the car has a low oil pressure idiot light that will do the same thing and you will probably notice that light first unless you are watching the gauge all the time. Oil temp is something that is good to monitor, but I don't need to see it every day. You can log it with EcuTek or Torque or any other OBDII logger.
Old 10-21-2013, 10:09 PM   #8
Admired
What kind of gauge pod do I need for this gauge? Also with the failsafe, can both boost and A/F be displayed on the gauge at the same time or is it just that they are interchangeable to read?
Old 10-21-2013, 10:14 PM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
Do I need to buy a gauge pod for the AEM Failsafe or does it come with a gauge mount?
You'll need a pod.
Old 10-21-2013, 10:25 PM   #10
Admired
Originally Posted by xjohnx View Post
You'll need a pod.
What pods is everyone using? Stupid question but does the failsafe read both boost and A/F at the same time?
Old 10-21-2013, 10:58 PM   #11
xjohnx
Grip>Slip
xjohnx's Avatar
I went with a pod that replaces my defroster vent on the drivers side.
looks like this:
It can read both boost and AF a the same time. Either PSI on the OLED in the middle and AF on the outer-rings LEDs, or vice versa.
Old 10-21-2013, 11:01 PM   #12
Sportsguy83
Drives: Limited BRZ
Yes, same time.
Old 10-21-2013, 11:06 PM   #13
Admired
looks like this:
oh thats nice, what pod is that? How much?
Old 10-22-2013, 01:16 AM   #14
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Mine is mounted in my side vent:
Pitman is offline   Reply With Quote
The Following 3 Users Say Thank You to Pitman For This Useful Post:
DAMotorsports (10-22-2013), mswhong (10-22-2013), Sportsguy83 (11-21-2013)
AEM Wideband Failsafe Gauge Pitman Forced Induction 51 08-14-2016 12:06 PM
LC-1 wideband 02 sensor MattF Engine, Exhaust, Bolt-Ons 4 11-05-2013 10:52 PM
Innovate LC1 wideband choi0706 Engine, Exhaust, Bolt-Ons 0 08-28-2013 12:29 AM
Wideband LC-1 wiring. MattF Forced Induction 9 07-09-2013 10:33 AM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
