Old 09-08-2021, 05:15 PM   #1
Longuy
Drives: 2013 FRS
BPV? JRSC pressure test
Im pressure testing my piping to throttle body not sure if the BPV is bad. When I hit 5 psi it makes a weird noise and will only hold 5 psi.. Here is a YouTube link
Beefaroni is only a lunch time treat .. see video
Thanks any help is appreciated,
Jeff
Longuy is offline   Reply With Quote
Old 09-08-2021, 05:53 PM   #2
Longuy
Drives: 2013 FRS
yes I plugged the bpv system pressured fine.. is this a indication of a bad bpv? or is this the way it is in test mode and not real time with vacuum/boost?
thanks
Jeff
Old 09-08-2021, 07:42 PM   #3
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Pull the BPV. Press the spring/lever in and then plug the vac line with your finger. It should not pop out.
You can also test it by hooking a brake bleeder/ hand vaccum pump up the the bypass valve, pump it to your vac pressure (12-15lbs) it should pull in the lever. Then watch the gauge to see if it holds pressure or and the needle doesn't move over a few minutes.
The Following User Says Thank You to Kiske For This Useful Post:
Longuy (09-08-2021)
Compression test numbers? Anyone done running comp test? Crunk81us Engine, Exhaust, Transmission 2 11-10-2017 01:35 PM
How to test fuel pressure? armstrom Engine, Exhaust, Transmission 5 08-30-2017 06:35 PM
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
Hey guys I recently test drove the 86 straight after test driving the Megane RS. Obsessionz Scion FR-S / Toyota 86 GT86 General Forum 32 09-23-2014 01:20 PM
P&L Header Dyno and Fitment test-With my Vortech Test Kit Huehuecoyotl Engine, Exhaust, Transmission 118 07-07-2013 10:26 PM
