Old 08-24-2017, 11:26 PM   #1
armstrom
Drives: none
How to test fuel pressure?
I'm having some issues with my tune and I'm trying to run through some diagnostics. I've ruled out pretty much everything I can but I need to check my fuel pressure (not the high pressure rail, I know there's a sensor for that already). Does anyone sell a part to tap into the fuel line to add a sensor? I've looked at the portions of the shop manual posted online but they don't really seem to include diagnostic techniques (which would usually call-out any special tools the dealer has access to).
If there isn't a ready-made solution can someone provide the fuel line connector specifications so I can piece together a system from fittings, T-s and adapters?
-Matt
armstrom is offline   Reply With Quote
Old 08-24-2017, 11:42 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
I think you have the right idea with cobbling together your own stuff. That's pretty much how the manual specifies.
https://demos.starbase7.net/t3Portal...00Q3M04GX.html
Old 08-30-2017, 02:07 AM   #3
armstrom
Drives: none
I created a DIY post on the setup I finally settled on. Hopefully it will help someone.
http://www.ft86club.com/forums/showthread.php?t=121645
-Matt
Old 08-30-2017, 01:03 PM   #4
Ultramaroon
not playing cards
Elegant!
Old 08-30-2017, 06:27 PM   #5
I use a @DeliciousTuning MK1+ FF kit, which has an in-line fuel pressure sensor for monitoring pressure from the in-tank pump to the port injectors.
Old 08-30-2017, 06:35 PM   #6
armstrom
Drives: none
Yeah, that works too but you need the flex fuel kit as well. Clearly, a great solution for people who want to run flex fuel. I can't get E85 near me so that system would be major overkill just to monitor fuel pressure. My solution used a $45 adapter, $20 sensor, $10 microcontroller and a $20 LCD. I will probably ditch the microcontroller and LCD and just datalog the voltage directly through the rear O2 port but on short notice it was easier for me to just cobble together my DIY setup.
-Matt
P0087 Low Fuel rail pressure GT86meMR2 Issues | Warranty | Recalls / TSB 17 05-15-2021 01:23 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
OEM cam differences, modifying fuel pressure. Crunk81us Engine, Exhaust, Transmission 29 06-03-2016 06:02 PM
Aftermarket Fuel pressure gauge FutureFT86 Engine, Exhaust, Transmission 2 03-10-2016 10:22 PM
frs low fuel rail pressure ? 15,000 miles j0hnnybk01 Issues | Warranty | Recalls / TSB 10 03-04-2014 03:03 PM
