| Software Tuning Discuss all software tuning topics. |
The Mechanic
Drives: Civic Turbo,FR-S
DBW TQ requested table??
So has anyone gotten the throttle body to stay open 97-99% up to redline?
This taper it does dropping to 90% after 5k is weird. im lightly changing the tables and getting no results.. I would also like to match the engine throttle relevance to match the pedal if that makes sense. Its dumb that at 80% pedal throw the engine is at 98% which is full throttle rendering the last 1/5th of my pedal swing useless. http://www.dirtyimpreza.com/forums/s...-to-Improve-it found this might just give it a go
#2 |
Drives: UK GT86
Be careful with which tables you edit and understand the relationship. You could actually reduce the throttle movement if you're not careful.
I think the throttle angle reducing is actually to do with the throttle itself and not a table in the map, it's certainly not something I've heard has been "fixed" I'll also suggest that you don't actually want a dead linear pedal, nor do you want 100% throttle at only 100% pedal. Mine goes fully open at 85% pedal and I think it's late enough, it's actually the control you get earlier on in the range that I found beneficial. But then I think the CBW is a personal thing, just it's trial and error. I've managed to make a setting I like which softens at lower pedal travel but is more linear 45~85%. Another reason that I wouldn't set it to 100/100 is that when the sensor does start to go, you'll lose full throttle straight away.
.: Stealth 86 :.
#3 | |
The Mechanic
#4 | |
Drives: UK GT86
Yes, those are the correct fuel modes.
.: Stealth 86 :.
#5 |
Drives: Built FA20
That post on dirtyimpreza is very informative. The one thing I see that I don't like about it is that the author doesn't include anything on the calculated torque tables. I read a thread on here (on my phone now so I won't link it) describing the relationship of calc. torque and requested torque as an equation with requested as a numerator and calculated as a denominator. That would effectively make edits to the requested tables useless. Or, as the author of the thread here noted, producing "undesirable results".
#6 |
Drives: UK GT86
The problem with that link is it doesn't 100% explain the working on our ECU.
I go by what's in ECUtek as I find it easier to understand, but the basics: A 2D WOT Threshold Table (Raw Numbers) - Requested Tq Base in Romraider A 3D Torque Request Table - Accelerator v RPM A 3D Requested Throttle Angle Table - Tq v RPM The values in the Torque request table are divided by the WOT threshold table. So at any point that the 3D Torque request table is above the value of the WOT threshold then you have 100% Requested torque. The value produced by requested torque divided by the WOT threshold is the x axis input for the throttle angle request table. I hope that makes sense. It's better explained here: http://www.romraider.com/forum/viewt...hp?f=15&t=7960
.: Stealth 86 :.
| The Following 2 Users Say Thank You to Kodename47 For This Useful Post: | Compelica (08-15-2023) |
#7 |
Drives: FT86
#8 | ||
The Mechanic
| The Following User Says Thank You to Grip Ronin For This Useful Post: | steve99 (04-09-2015) |
#9 | |
Drives: UK GT86
The throttle position max is different on Romraider t what I have on ECUtek, their max value is 86 which makes more sense. You can correct the definition by changing the expression: Code:
<table type="3D" name="Target Throttle Plate Position Maximum (Requested Torque)" category="Drive-by-Wire Throttle (DBW)" storagetype="uint16" endian="big" sizex="17" sizey="16" userlevel="4" logparam="E38">
<scaling units="Target Throttle Plate Opening Angle (%)" expression="x*0.00190734863272251" to_byte="x/0.00190734863272251" format="0.00" fineincrement=".1" coarseincrement="1" />
<table type="X Axis" name="Requested Torque" storagetype="float" endian="little" logparam="E56">
<scaling units="raw ecu value" expression="x" to_byte="x" format="0.000" fineincrement="1" coarseincrement="10" />
</table>
<table type="Y Axis" name="Engine Speed" storagetype="float" endian="little" logparam="P8">
<scaling units="RPM" expression="x" to_byte="x" format="#" fineincrement="50" coarseincrement="100" />
</table>
<description>The target from the 'Requested Torque (Accelerator Pedal)' table and engine speed are used to determine the maximum limit target throttle plate opening. This maximum target throttle plate opening is used to limit the final target throttle plate opening determined by the A/B tables.</description>
</table>
.: Stealth 86 :.
#10 | |
The Mechanic
#11 | |
Drives: UK GT86
86 degrees is 100% throttle. When I log requested throttle it shows as 100%.
.: Stealth 86 :.
#12 | |
The Mechanic
i got the throttle plate changed to 86 degrees tho
#13 | |
Drives: UK GT86
![]() I wouldn't touch the requested torque table definition, there's no need as they are raw values.
.: Stealth 86 :.
#14 | |
The Mechanic
lol i raised some values at the high end and it drives the same but engine off it only opens 64% lolnoticed my injection goes port only recently on closed loop. i dont recall this happening before but i dont like it lol
| AFR table | nickw14 | Software Tuning | 9 | 04-01-2015 06:14 PM |
| f.s. Open flash table | slofrs | Engine, Exhaust, Bolt-Ons | 3 | 12-31-2014 11:07 AM |
| 2014 PAX table | Scooby South | Tracking / Autocross / HPDE / Drifting | 11 | 11-26-2013 11:35 AM |
| Help posting a Table / Spread sheet | Esoteric | Site Announcements / Questions / Issues | 1 | 07-28-2013 12:48 AM |
| Coffee table I made from my FRS OEM springs | FR-Shadow | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 12-16-2012 07:05 PM |
