| Software Tuning Discuss all software tuning topics. |
Drives: GT86 2013
Accessing "hidden" gear in an auto
I have an auto gt86, and pretty much always drive in manual mode except when using cruise control. I keep finding myself in a position where 5th is too high and 4th is too low. In auto there is an extra gear there to fill the gap, a 4.5 gear. Is there any way to access this gear in manual mode?
via Imgflip Meme Generator
#2 |
Drives: 2013 Hot Lava FRS
Uh... no there isn't?
#4 |
Drives: GT86 2013
At 90kph in auto at slight uphill rpm sits at 2krpm, if i put it in manual it rises to 2.5krpm in 4th gear. Changing up to 5th gives 1.6krpm.
Numbers are approx and by memory, but it is consistent. I am prepared to be laughed at if there is something i'm missing btw:p |
#5 | |
Drives: FT86
You likely feeling the torque converter "lockup" most modern autos do this for fuel economy see here http://www.ft86club.com/forums/showthread.php?t=18868 |
| The Following User Says Thank You to steve99 For This Useful Post: | skogs (10-25-2017) |
#6 | |
Drives: 2015 brz
YES, PRESS THE BRAKE PEDAL AND HOLD THE SHIFT BUTTON AND SHIFT UP HALF WAY |
#7 |
Drives: GT86 2013
#8 |
Initial G
Drives: 13 FR-S, 15 BMW 228i
I don't think that would constitute a different gear ratio, it's just allowing some slip when it's not locked, so the engine revs higher.
2013 FR-S
2015 BMW 228i |
| The Following User Says Thank You to srt4evah For This Useful Post: | skogs (10-25-2017) |
#9 |
Drives: Man
Is it possible to code to show the current auto gear you are currently on? Just like when you in manual gear mode, it shows via M1 - M5 - M8 with each shift.....
| Blinking carat "arrow" in Dashboard Gear Display | 2017-BRZ | BRZ First-Gen (2012+) — General Topics | 14 | 03-29-2017 02:06 PM |
| 2015 Series.Blue Engine "Chirp"and 2nd Gear Grind | s30series | Issues | Warranty | Recalls / TSB | 33 | 09-07-2014 02:26 AM |
| Scion FR-S: Adjusting the headunit / NAV "hidden menu" settings | EsoBOFH | DIY (Do-It-Yourself) Guides | 17 | 04-30-2014 11:11 PM |
| "This repair is not covered by Subaru's limited warranty" RE: 4th gear tranny grind | DoomsdayJesus | Issues | Warranty | Recalls / TSB | 108 | 04-29-2014 02:15 AM |
| Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode | SteveH | Other Vehicles & General Automotive Discussions | 7 | 02-13-2013 01:08 AM |
