Old 03-24-2017, 10:35 AM   #1
balci
spacer, stud clearance on rota GRA
got these 18x7.5 et48 rota GRA's at home, and I'd really like to add some spacers
now, I dont have them in front of me, but heres a pic
do you think 20/25mm spacers would fit? considering the OEM lugs would be poking out quite a bit, and without having the car or wheels near me atm, are those extra holes meant for the oem lugs? they seem kinda small to me
balci is offline   Reply With Quote
Old 03-24-2017, 05:54 PM   #2
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
The extra holes are most likely just there to mimic the look of whatever wheel that Rota based that design off of. Certainly not for the lugs
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Brakes, Suspension, Chassis 1 10-05-2016 01:48 PM
Lug nuts, spacer, ARP extended wheel stud, camber bolt, fumoto drain valve Jesse0923 Wheels and Tires 0 10-01-2016 10:50 PM
Clearance and spacer query pooch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-21-2016 09:30 AM
H&R DRS Spacer (3025560) Stud installation question Dihudaxia Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-19-2015 10:16 PM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 12:59 PM
