| AUSTRALIA Australia and New Zealand |
Drives: 86 GTS
Ethanol
Delete!
#2 |
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
why not just run non-ethanol fuel?
#3 |
Drives: Black 86 GT
Agree. Toyota recommend 98 Ron and the handbook states that 95 can be used without detriment to the engine if necessary but not sure how they will react if they know that 100 has been put in. Will be interesting to see how it works out.
#4 |
Drives: Pearl 86 GT
get flex fuel sensor. Issue resolved. I ran it on E85 from United for awhile and there was no issue.
Reason went back to 98. No map. really nice. Waiting for new E85 map.
White GT | Visconti_TUNED
#5 |
Senior Addict
Drives: 86 GT
Just curious, did the issue go away when you switch back to non-ethanol 98? Or is the damage irreversible and requires new HPFP?
#6 | |
Grand PooBah
Drives: Toyota 86 GT MT
i suggest you go back and check again because it implicitly states that 98 or higher is optimal however the engine can be run without detriment on 95 octane however it will not run at maximum performance. I am also reasonably sure it states in there that fuel with up to 10% ethanol is fine to use too.. There are several boys in sydney running E85 without issue. The crickets on the other hand is a known issue even in circumstances where people havent touched ethanol. Its just a coincidence IMO |
#7 |
Drives: BR86
Personally I have never used any fuel mixed with ethanol, only Shell VPower, yet I still have the crickets and according to my Toyota tech "it is what it is" a Toyota designed HPFP & nothing can be done to correct the issue atm :/
I would also not recommend the use of ethanol mixed fuels due to a school of though amongst mechanics & technical experts that it accelerates corrosion of the fuel system ! |
#8 | |
Grand PooBah
Except the topic of your thread is "dont use ethanol based fuel".... My point is; why shouldnt people use ethanol blended fuel? Because you used it and had the cricket issue (that is already a known issue and as ZZT86 demonstrates, not neccessarily associated with ethanol in any way.) The car is stated as fine to operate with fuels containing up to 10% ethanol which the united 100 octane does. Your thread as it stands is invalid. Maybe you should look into the numerous "what is causing the cricket noise" threads before providing us with your expert diagnosis.
#9 |
Drives: 86 GTS
RAN94B so sorry I was only repeating what the Toyota mechanic told me and two other mechanics that I spoke to. The SERVICE BULLETIN stated that "certain fuel temperatures or fuel formulations" cause the issue …. so thank you for providing us with your BULLSHIT expert diagnosis.
I will check with you first before I post next. So how long have you suffered small D*** syndrome? Last edited by Andrew666; 07-23-2013 at 12:12 AM. |
#10 |
Drives: 86 GTS
Deleted
#11 |
Drives: Toyota 86 GTS
Want to delete tread?
Go drifting |
#12 |
Drives: Black 86 GT
#13 | |
Drives: Black 86 GT
Oh dear!
#14 |
Drives: 86 GTS
Well that went south quickly....
| Why does the fuel pump not do well with ethanol? | boredom.is.me | Engine, Exhaust, Transmission | 42 | 02-28-2019 07:21 PM |
| Where to get non ethanol fuel? | mhigham | Engine, Exhaust, Transmission | 19 | 11-13-2012 12:27 PM |
| Ethanol fuel treatments | JoeBoxer | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 09-19-2012 12:42 PM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 05:53 PM |
| Website that locates ethanol-free fuel | wbradley | Issues | Warranty | Recalls / TSB | 8 | 07-24-2012 01:47 AM |
