Old 03-04-2016, 07:18 AM   #1
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Surging Idle
My idle is surging from 1grand to 500. Does it when I'm parked and when I'm at a light with clutch depressed and car in neutral
Anyone else have this problem
RichardsFRS is offline   Reply With Quote
Old 03-04-2016, 07:36 AM   #2
crsmlr
Drives: 16 FRS
I've seen this posted before but I'm not quite sure what the solution is.. I'm driving a 16 frs with maybe 4000 clicks on it.. and it's done since I pulled it outta the show room
Sent from my SM-G900W8 using Tapatalk
crsmlr is offline   Reply With Quote
Old 03-04-2016, 07:43 AM   #3
RichardsFRS
Ahh well it might be normal. I read some articles where its an ecu problem and Toyota will re-flash but mines a 13 with 46k on it. I do have an extended warranty.
Old 03-04-2016, 08:02 AM   #4
swarb
Seriously. Search. There is a sticky on top of this section for tsbs. And a many threads on this subject.
http://www.ft86club.com/forums/showthread.php?t=21868
The Following 5 Users Say Thank You to swarb For This Useful Post:
Cole (03-04-2016), FRSBRZGT86FAN (03-04-2016), lupindub (03-05-2016), Sideways? (03-05-2016), soulreapersteve (03-04-2016)
Old 03-04-2016, 08:53 AM   #5
RichardsFRS
I saw the sticky. 15 to 16 models
Mines a 13. Guess I'll check the vin anyway
Old 03-04-2016, 08:58 AM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Is your AC or window defroster on?
Old 03-04-2016, 09:17 AM   #7
RichardsFRS
Heater was on, but no defrosters. Chilly this morn but it did it last weekend and it was in 70s. TSB says occurs after 25 minutes or more of highway driving then stopped. Also tsb is automatic mines manual
The Following User Says Thank You to RichardsFRS For This Useful Post:
go_a_way1 (03-04-2016)
Old 03-04-2016, 09:21 AM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Okay cuz I know when it blows any air to the windshield it puts AC on to dry out the air so it doesn't fog, even if the heater is on and that might have caused it. Its highly unlikely but you may also have a super small vacuum leak after the MAF sensor?
Old 03-04-2016, 05:48 PM   #9
swarb
Seriously? SEARCH harder.. . SEARCH
S-SB-0040-13 : Intermittent RPM Drop
Applicability
YEAR(S) MODEL(S) ADDITIONAL INFORMATION
2013 – 2014 FR-S
Introduction
Some Scion FR-S vehicles may exhibit an engine RPM drop while idling with the A/C off. The Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM) logic has been revised to address this condition. Use the following repair procedure for ECM (PCM) reprogramming.
The Following 2 Users Say Thank You to swarb For This Useful Post:
Old 03-04-2016, 05:56 PM   #10
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
The other ones are specifically for automatics......
Old 03-04-2016, 06:01 PM   #11
swarb
Dammit why did you link it? LOL
I want him to learn to search and read... this isn't the first time... or second... or....
Old 03-04-2016, 06:52 PM   #12
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Surging Idle
My car does this sometimes too, live with it or get real good gas.... Doesn't seem to do it if I just put some octane booster in.. But probably just placebo effect. LoL
Mine is 15 & I complained to the dealer & there was not thing they can do since my ecu/pcu is obvious on the new firmware already...
Old 03-04-2016, 07:16 PM   #13
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
You can only teach a man how to fish so many times before you say fuck it, break the rod, and walk away...
The Twins make me smile
The Following 2 Users Say Thank You to soulreapersteve For This Useful Post:
Tcoat (03-04-2016), Ultramaroon (03-05-2016)
Old 03-05-2016, 12:57 AM   #14
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Play nice or I'll make you guys play nice. It's up to you.
ichi
The Following 5 Users Say Thank You to ichitaka05 For This Useful Post:
86kahl (03-05-2016), flippy (03-05-2016), FRSBRZGT86FAN (03-05-2016), Tcoat (03-05-2016), Teseo (03-05-2016)
Idle dip yomny Software Tuning 38 06-14-2016 06:54 PM
Idle at 4 psi? LS1M Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 07-18-2015 01:01 PM
K&N idle dip Dominus Engine, Exhaust, Transmission 7 01-28-2015 11:17 PM
AFR @ Idle woode Forced Induction 12 01-19-2014 09:38 PM
Odd idle jbixel Issues | Warranty | Recalls / TSB 2 11-02-2013 09:35 AM
