| CANADA Canada |
Drives: 2015 Halo FR-S
No traction control/ABS light on
Reason for traction control to be permanent disengaged controls wot work no lights on only swerve light under rpm also abs light on. Anyone help me out and know why?
#2 |
1. check fuses
2. pull code 3. take it to the dealer |
#3 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Dude check your airbag sensor when you took your steering wheel off
#4 |
Air bag sensor is taken car of
#5 |
ABS light on *might* mean there's something wrong in the ABS system...
Check if any codes are stored, and/or take it to the dealership.
#6 |
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
If you have an aftermarket steering wheel and in any way messed with or removed the clock spring underneath, I've heard this could be a cause.
Part of the reason why I switched back to my OEM wheel after only 3 days with a Nardi.
@bpennerz
| The Following User Says Thank You to SLVRSRFR For This Useful Post: | Cole (01-13-2016) |
#7 |
Drives: Black on Black on Black
I actually had this issue start last week. (the first heavy snow and then I guess it flash froze some of it?) Apparently Front Driver side ABS Speed Sensor Died/tore/broke/crappedout on me thus leaving me with Solid Slip light and ABS lights on.
I have an ODB Reader, No codes at all. Pulled and checked ALL checkable fuses under the hood and Under the steering wheel. Gave up and took her to the dealer Took a week to order the part and get replaced. All courtesy of the dealer. Literally just picked her up from the dealer not more than 20 minutes ago |
| Engine Check light, Traction Control light, cruise control light all on suddenly | wqc3241 | Software Tuning | 2 | 01-10-2016 08:37 AM |
| ABS and Traction Control Light on -> ABS Actuator Went Out | N1rve | Issues | Warranty | Recalls / TSB | 11 | 11-29-2015 09:35 PM |
| Traction control light at high RPM | wizzo | Issues | Warranty | Recalls / TSB | 17 | 06-27-2015 06:18 PM |
| Traction control, abs and brake light all on? | JMoore412 | Issues | Warranty | Recalls / TSB | 0 | 08-12-2014 08:27 PM |
| lowered car and traction control light came on | Shipwreck | Issues | Warranty | Recalls / TSB | 2 | 11-05-2013 06:18 AM |
