Old 01-11-2015, 12:09 AM   #1
calic
calic's Avatar
Drives: Subaru Brz
AT transmission hard shifting issues
I just got this car less than two weeks. I have about 900 on the odo. I've been searching different threads, couldn't find an exact answer.
I love the manual mode in the car. I have been having one issue. Most of the time the car upshifts so smoothly.
But once and while the car will kick back (jerk) when shifting into 2nd or 3rd. When shifting I usually keep my foot on the pedal the entire time. It will stay like this during the entire drive. It's less noticeable if i take my foot off the gas during the shift.
And when I turn off the car it will return back to normal. Shifts like butter. I'm worried this could become a problem later.
calic is offline   Reply With Quote
Old 01-11-2015, 12:48 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Is the car warm when you're driving it?
N1rve
Old 01-11-2015, 01:12 AM   #3
calic
calic's Avatar
Drives: Subaru Brz
always.. It shifts like butter when i usually start it cold. Then if i stop or after a while driving the hard shifting starts up.
Old 01-11-2015, 01:22 AM   #4
N1rve
N1rve's Avatar
That's odd. When the car is cold, I have aggressive and hard shifts from 1-2. When it's warm the car is always smooth (except in sport mode).
Does your car whine when you accelerate at low RPMS?
N1rve
Old 01-12-2015, 01:27 AM   #5
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
I have the same issue on my FRS. It seems to happen most when I shift into manual mode after driving hard, or after traffic. If I leave it in manual mode from the start its fine.
V_86 is offline   Reply With Quote
The Following User Says Thank You to V_86 For This Useful Post:
FRSBRZGT86FAN (09-09-2015)
Old 01-12-2015, 01:58 AM   #6
WesleyG
Drives: 2014 Satin White Pearl GTS auto
it happens to me once or twice after a very very spirited blast in manual mode, when i put it back into auto
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 01-12-2015, 05:36 AM   #7
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
I had the same issue, it's been gone for a while. Never pinned it down. If you let off while shifting, it won't buck but if your foot is on the pedal hard it feels very shitty when it shifts.
It's not temperature or load, as I've experienced it a bunch of times in entirely different conditions. I usually pull over, turn the car off, wait a minute or two, and start up again. that usually fixes it.
But for two solid hours of tracking with no upgraded radiator or oil cooler, I had zero issues the whole time. I can't figure out what the prob is haha.
My car did it early on (low mileage) but I'm at about 4k miles now and I haven't had that issue for a while.
Maybe the transmission or ECU sorts its own shit out after a bit?
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
The Following User Says Thank You to fatalelement For This Useful Post:
TofuJoe (05-21-2017)
Old 01-12-2015, 08:13 AM   #8
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
I will say I also have the same problem with my AT.
rjgough95 is offline   Reply With Quote
Old 01-12-2015, 09:40 AM   #9
AJPG
Drives: 22RE, FA20, 4G63
AJPG is offline   Reply With Quote
Old 01-12-2015, 11:25 PM   #10
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Most AT issues will come down to the fluid. The tolerance for fluid level in this car is extremely tight. And if it's out of its operating range the volume will change. If the fluid level isn't right it becomes harder to shift.
Manual & sport modes are supposed to have aggressive shifts, the only time I hear something from mine is from 5th to 4th I hear a small clunk which is only because of my hollow tail shaft amplifying the noise.
It shouldn't sound like there's something wrong with if though. If it sounds sick, it is.
Old 01-13-2015, 12:16 AM   #11
V_86
V_86's Avatar
The main issue seems to be jerky shifts. It still shifts, but it feels odd. Does anyone know if changing the fluid help at all? I've had this problem since a little after 1000 mi.
Old 01-13-2015, 09:37 AM   #12
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Ok, so as @fatalelement elluded to: is it safer to lift while shifting in M or not? having your foot at > 50% throttle makes awesome shifts but when it's cold you get a rough shift
drewbot is offline   Reply With Quote
Old 01-13-2015, 12:09 PM   #13
V_86
V_86's Avatar
With a torque converter it shouldn't make a difference if you lift or not I would think. Once it starts acting up, it does not seem to matter what position the throttle is in
Old 01-13-2015, 01:40 PM   #14
calic
calic's Avatar
Drives: Subaru Brz
For example today, it actually happened during my drive. It was smooth as butter , then during my drive it started to shift roughly again. But then yesterday it was smooth as butter all day.
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 10:57 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 01:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 04:22 PM
hard shifting in sport mode AT sofrsnsokleen Issues | Warranty | Recalls / TSB 11 12-12-2012 12:13 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
