Old 07-31-2012, 02:38 AM   #1
wootwoot
Drives: FRS
Light weight flywheel and crank pulley?
I think a few people around here are running a light weight pulley and flywheel. Can anyone chime in and tell us how it is going? Any CL's or idle problems?
Old 07-31-2012, 04:02 AM   #2
wu_dot_com
Drives: accord
Yes and no. I'll have to discuss the detail with Perrin prior to releasing the information.
wu_dot_com is offline   Reply With Quote
Old 07-31-2012, 05:10 PM   #3
wootwoot
Drives: FRS
Interesting... Anyone else?
Old 07-31-2012, 05:24 PM   #4
xcelir8brz
Drives: 2013 BRZ Limited
No issues here!
xcelir8brz is offline   Reply With Quote
The Following User Says Thank You to xcelir8brz For This Useful Post:
charged86 (09-11-2013)
Old 07-31-2012, 05:33 PM   #5
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Originally Posted by xcelir8brz View Post
No issues here!
Your running both ?
Sent from my GT-I9300 using Tapatalk 2
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 07-31-2012, 05:38 PM   #6
KronosPerformance
KronosPerformance's Avatar
Drives: 2009 Subaru STi
Send a message via AIM to KronosPerformance
Both lightweight flywheel and pulley do and affect 2 different things
As long as the diameter is the same on the pullies are the same as factory and not smaller, there are no adverse affects. Its just less rotating mass which helps your pulley system move easier.
Lightweight flywheels can however have adverse affects depending on how low in weight you go. This will affect driveability whether its how much power it takes to get moving, how quick revs drop out of your powerband in between shifting, easier to stall and things of that nature. Its one of those things that the less weight isn't always for the better.
Too light will drastically change your driving style, increased chattering and make it easier to stall.
Cliff Notes: You can run both no problem...lightweight flywheels can have more negative affects if you go too low.
KronosPerformance is offline   Reply With Quote
The Following 4 Users Say Thank You to KronosPerformance For This Useful Post:
Anduz (11-08-2012), BLACK->BULLET (06-01-2015), Bonburner (07-31-2012), wu_dot_com (07-31-2012)
Old 07-31-2012, 05:59 PM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
Wow, that was the most useless post I've read in a while. Why don't we have an un-thanks button?
The Following 27 Users Say Thank You to Calum For This Useful Post:
20valvewynn83 (09-24-2012), Bluecille (11-05-2012), Celica00 (11-01-2012), chanomatik (11-14-2014), CodyFRS (09-08-2013), Dseaman (09-07-2013), FRSPirate (08-01-2012), Ingen (11-05-2012), JS86JS (09-08-2013), karma003 (11-05-2012), Lemar58 (05-12-2014), limitedblkwrx (01-01-2015), Maverick22 (01-21-2015), mitch t (11-14-2016), Mr. (09-04-2013), ngabdala (08-01-2012), OrbitalEllipses (08-01-2012), oso_25 (09-05-2012), Ramster (06-04-2014), rhythmM (09-05-2014), SloS13 (03-18-2013), soros151 (11-09-2012), Strife26 (07-07-2017), Surok (10-31-2012), topazsparrow (09-03-2013), Tye300 (06-24-2013), Votlon (06-15-2016)
Old 07-31-2012, 07:28 PM   #8
wootwoot
Drives: FRS
No issues here!
Can you tell us which flywheel and which pulley you are running?
KronosPerformance- Do you think it is just a matter of time before someone puts in the research to find the optimal weight for the FRS? It seems most fly wheels I come across are 12lbs. I wonder how that would do?
Old 07-31-2012, 07:36 PM   #9
xjohnx
Grip>Slip
xjohnx's Avatar
Pretty sure that if privacy was a concern, you've already posted too much.
The Following 7 Users Say Thank You to xjohnx For This Useful Post:
20valvewynn83 (09-24-2012), chanomatik (11-14-2014), charged86 (09-11-2013), mike2100 (07-31-2012), Mr. (09-04-2013), ngabdala (08-01-2012), Tye300 (06-24-2013)
Old 07-31-2012, 08:22 PM   #10
wu_dot_com
Drives: accord
no privacy is not a concern, but i rather discuss my findings with both the flywheel manufacture and perrin before releasing those information prematurely.
there were some interesting findings, and i am looking to see if there were any problem with prolong usage.
plus, i just installed them last night, i think its a common courtesy to let both perrin and the flywheel manufacture know the integration results of their product first.
ill post my experience tomorrow after a 200 mile drive test.
Old 07-31-2012, 09:29 PM   #11
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
so gtfo and drive!!!!!!!!!
Silverdub is offline   Reply With Quote
The Following User Says Thank You to Silverdub For This Useful Post:
Old 07-31-2012, 11:02 PM   #12
KronosPerformance
Sorry for the delay. There really isn't a "optimal" weight. Its whatever the driver thinks is best for them. Some want the absolute lowest because they prefer that driving style and want the instant RPM jump in power, some just drive to the local grocery store. Some people may not care at all and can adapt to the difference. It really just depends on the driving style and what you're looking to do with your car.
Also depends on what the weight of your factory flywheel is as well. That I'm not sure off hand what the weight is on these cars.
The Following User Says Thank You to KronosPerformance For This Useful Post:
ST185RC (03-12-2013)
Old 08-01-2012, 02:45 AM   #13
wu_dot_com
Drives: accord
Well the stock flywheel, clutch and pressure plate assembly weights about 37lbs
Old 08-01-2012, 08:24 AM   #14
KronosPerformance
I mean more so the weight of the flywheel alone.
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-05-2019 12:37 AM
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 07:45 PM
Agency Power Crank Pulley / Clutch Masters Flywheel vividracing Engine, Exhaust, Transmission 67 11-07-2012 03:35 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 04:47 PM
