Old 11-11-2014, 05:23 PM   #1
norcalpb
norcalpb's Avatar
BRZ HUD Gear Indicator Missing?
I know there's a gear indicator setting that is found under the odometer button, but I can't seem to find it on my 2013 BRZ. I recently adjusted the clutch but adjusted the clutch button as well so it made full contact. Still no luck.
I never checked to see if my car had this feature before I adjusted the clutch, so I was just making sure 2013 BRZs had this feature.
Thanks!
Old 11-11-2014, 05:29 PM   #2
PAbrz
PAbrz's Avatar
Drives: '13 DGM BRZ 6 M/T
[ame="https://www.youtube.com/watch?v=fB9dcC9dl3w"]Scion FR-S: How to set the Shift Light & Gear Indicator Display Settings (BRZ GT86) - YouTube[/ame]
PAbrz is offline   Reply With Quote
The Following 2 Users Say Thank You to PAbrz For This Useful Post:
norcalpb (11-11-2014), torqueno (11-11-2014)
Old 11-11-2014, 06:07 PM   #3
wheelhaus
wheelhaus's Avatar
The FRS and BRZ gauge clusters are different, and I don't believe the BRZ has the gear indicator or economy shift indicator as the FRS. If it does, I haven't found it.
Old 11-11-2014, 06:31 PM   #4
Pkush
BRZ has both. At least the 2015 Series.blue does.
Pkush is offline   Reply With Quote
The Following User Says Thank You to Pkush For This Useful Post:
wheelhaus (11-11-2014)
Old 11-11-2014, 06:33 PM   #5
bababooey
Drives: BRZ SWP Limited -6MT
my 14 does have both as well
bababooey is offline   Reply With Quote
Old 11-11-2014, 06:34 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
It's just defaulted off, for whatever reason.
Old 11-11-2014, 06:36 PM   #7
wheelhaus
wheelhaus's Avatar
After watching that video I think I may be wrong. I hope I am, will try tonight on my way home from work.
The Following User Says Thank You to wheelhaus For This Useful Post:
Pkush (11-11-2014)
Old 11-11-2014, 06:51 PM   #8
Akari
Drives: 2013 DGM BRZ
Yeah, my 2013 BRZ definitely has it. Defaulted to off from the dealership.
Akari is offline   Reply With Quote
The Following User Says Thank You to Akari For This Useful Post:
sftateofmind (06-03-2015)
Old 11-11-2014, 08:42 PM   #9
norcalpb
norcalpb's Avatar
I'm so dumb, thank you guys =)
Old 11-12-2014, 11:55 AM   #10
wheelhaus
wheelhaus's Avatar
confirmed, mine is 1st year and it does indeed have it. I thought it was in the shift light menu, not the odomoeter menu... Its there!
Old 11-16-2014, 06:51 PM   #11
pl1ght
Drives: 2015 Alfa Romeo 4C
Sweet, didnt even know i had this feature, turned it on my '14 limited.
pl1ght is offline   Reply With Quote
Old 11-17-2014, 10:57 PM   #12
gravitylover
I tried a few times and I don't think the gear indicator feature is on the premium model. I can set the rev limit beep but it doesn't go to the next step with the gear indicator. Wouldn't surprise me if I'm missing something...
Old 11-18-2014, 03:12 AM   #13
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Don't actually start the car. Just go to accessory power with your key, then you should be able to access the G-on/off when you press through with the ODO / TRIP button.
dhuang is offline   Reply With Quote
Old 11-18-2014, 08:58 PM   #14
gravitylover
Tried again and it goes odo/trip a/trip b and that's it. Am I supposed to hold the button down or ...?
How to set the Shift Light & Gear Indicator Display Settings EsoBOFH DIY (Do-It-Yourself) Guides 76 04-21-2020 09:42 PM
FT86 GT manual gear indicator KamalT Engine, Exhaust, Transmission 3 10-04-2012 10:43 PM
MT gear indicator WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 19 07-02-2012 11:20 PM
MT Gear Indicator Issue civicdrivr Scion FR-S / Toyota 86 GT86 General Forum 28 05-22-2012 12:40 AM
Gear indicator Slick CANADA 18 05-20-2012 11:14 AM
