Old 05-05-2013, 01:26 PM   #1
pdreams
Clutch pedal springy sound
Hi,
Start to notice that my clutch pedal is giving me a "springy stretching" sound towards the end of the pedal stroke.
Sounds like a lack of lubrication or some spring is getting old. I have around 14000miles on the car now.
Sound is audible from outside the car when depressing the clutch pedal. Had sprayed lots of lubricant inside the car but sound comes out after the car has been driven for some time.
Anyone facing the same issues?
Cheers
pdreams is offline   Reply With Quote
Old 05-05-2013, 01:38 PM   #2
whtchocla7e
Drives: 2013 FR-S Hot Lava
I hear something similar but I wouldn't call it an issue. It's always been there. These cars are raw in terms or mechanical feel/sound.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 05-22-2013, 11:44 AM   #3
450hp/tonne
Drives: 2011 Corolla Ascent Sport
Clutch pedal noise/knock is on every manual 86, but you have to be tuned in to hear it. I've asked others to press the clutch and they can't feel/hear it, when I can from the passenger seat. It is the clutch switch:
[ame="http://www.youtube.com/watch?v=uKlqP1blfeg"]Clutch Noise - YouTube[/ame]
450hp/tonne is offline   Reply With Quote
The Following 2 Users Say Thank You to 450hp/tonne For This Useful Post:
rawbz (06-18-2013), whtchocla7e (05-29-2013)
Old 05-22-2013, 01:04 PM   #4
Fizzo
Fizzo's Avatar
Drives: Rocket Bunny GT86
Ive had the same problem right around the same 15,000 kms, went into the service guys, they lubed behind the pedal and under the hood where the clutch pump is. it took a bit of time till the lube settled in, i sometimes hear it and mostly no.
Raven Rocket Bunny GT86 in Dubai
Fizzo is offline   Reply With Quote
Old 05-29-2013, 02:33 AM   #5
SoCal_86
テック
SoCal_86's Avatar
Drives: 85 Toyota Corolla GTS 13 Scion FRS
ah, this is exactly what I hear/experience also!!!
SoCal_86 is offline   Reply With Quote
Old 05-29-2013, 05:40 AM   #6
radroach
Drives: car
im not sure if my clutch switch, sensor sticks out that far. I'll check tomorrow and make sure, but I think mine is much shorter than that.
Old 05-29-2013, 12:37 PM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Mine makes a creaky noise, but it's the clutch itself, waiting for 35k for warranty replacement...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-29-2013, 01:59 PM   #8
bakerr6
Drives: 2013 raven black fr-s
same
bakerr6 is offline   Reply With Quote
Old 05-29-2013, 02:24 PM   #9
Overland'n'5thGEN
Overland'n'5thGEN's Avatar
Drives: 5th Gen Toyota 4Runner
I get the sound too. Had it on my 350Z as well. Not really worried about it.
sent from a Galaxy SIII...
Overland'n'5thGEN is offline   Reply With Quote
Old 05-30-2013, 06:51 AM   #10
pdreams
Had my issue solved at the dealer, basically they said the clutch fork is not lubricated well.
You can see this mechanism in the engine bay move as you step on the clutch.
Hope this helps.
Cheers
Old 06-12-2013, 09:28 AM   #11
450hp/tonne
If you put your head (awkwardly) under the pedals looking up, you will see and hear the spring at the top of the clutch pedal - I can occasionally hear it whilst driving. If this is what you are reporting, a little lube will fix you up.
Hope this helps.
Cheers
So they lubricated and the noise went away, or they explained it to you and you were happy to live with it after that? If they repaired, what exactly did they do (i.e. dropped the gearbox)?
Old 06-12-2013, 12:04 PM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yep, aware of that and the difference. This is coming from the clutch, verified with the car in the air. It's also clearly coming from the center of the car, not from the pedal box
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-13-2013, 05:07 AM   #13
pdreams
The sound was gone and the springy feeling also disappeared.
They told me which part they had greased. You can access it from the engine bay.
However, I can almost feel the sound coming back again ever so slightly. I think this clutch pedal does not withstand half clutch action in hot weather. It does not help there's alot of choke up traffic so there's quite alot of clutch work. If it comes back, I just have to grease the part in the engine bay again.
Old 09-17-2013, 05:16 PM   #14
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Any pics of the part in the engine bay?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 02:10 AM
New Clutch Pedal Stopper -- Bang For The Buck Mod!! 86_ZN6 Interior Parts (Incl. Lighting) 1 04-17-2013 11:26 PM
Clutch Cicking Sound KapteinBos AFRICA 9 03-01-2013 06:25 PM
Sound from Clutch KingRohan Issues | Warranty | Recalls / TSB 5 10-17-2012 10:10 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 06:01 PM
