Old 04-30-2015, 05:33 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Porsche Patents a Variable Compression Ratio
Interesting concept.
http://www.extremetech.com/extreme/2...uel-efficiency
Old 04-30-2015, 05:58 AM   #2
serialk11r
Drives: '06 AM V8V Coupe
No. Variable connecting rods is a horrible idea. The connecting rods are the components that see the greatest stress, why would you want to add moving gadgetry to them?
Lotus' moving puck idea is probably the best. For a 4 stroke engine, place the spark plug in a moving piston for a bit of compression ratio adjustment.
Old 04-30-2015, 09:08 AM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Not to mention the weight.
Old 04-30-2015, 02:33 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
VW's were just getting too dang reliable after they fixed the exploding fuel pump.
At first glance nifty, anything that prolongs the viability of combustion engines is a-ok in my book, while the article focuses on reducing turbo lag I immediately take this as a way to create a truer modern atkins cycle with an intake stroke shorter than the expansion stroke, maybe not at first but it's possible.
ineedyourdiddly
Old 04-30-2015, 02:53 PM   #5
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Like most German designs that are ahead of the curve: It will work brilliantly...briefly. (also: see "Alfa")
PRO86 | WTCC | STL
Old 04-30-2015, 04:52 PM   #6
serialk11r
You don't want that thing to be moving around much...lol
There is absolutely nothing wrong with the valve timing implementation of Atkinson cycle right now. Displacement is cheap and not hard to add.
The reason you want variable compression ratio is because when at part throttle, the combustion chamber temperature is going to be pathetically low and efficiency is horrible. So ideally you'd be able to adjust compression ratio up to like 30:1 at idle and reduce it to 10 at full throttle to keep burn temperature up.
Having a higher static compression already helps low load efficiency quite a bit as can be seen with Mazda's Skyactiv line, because 13-14 vs. 10 is quite a huge difference already.
Old 04-30-2015, 09:25 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
They used turbo lag as a reason to keep compression down alluding to the fact that as boost is low, comp will be raised up.
Doesnt make sense when they use VGT's. The article also never mentions DI either, which the new corvette ZO6 uses at a 10:1 ratio.
Increasing the ratio is a complicated idea, since as soon as your past idle, the compression is dynamic not static.
Old 04-30-2015, 11:21 PM   #8
Poodles
Drives: 2015 Series.Blue
The Germans have never understood the KISS principal. "German engineering" simply means over-complicated and costly to replace when it inevitably fails.
Continuously Variable Transmission Lexicon101 Other Vehicles & General Automotive Discussions 79 06-26-2015 03:18 AM
Variable Gemoetry Turbo (VGT) cdrazic93 Forced Induction 29 02-12-2014 11:12 AM
Mysterious Toyobaru Patents? STIITS Scion FR-S / Toyota 86 GT86 General Forum 27 10-17-2013 01:29 PM
Rotrak variable supercharger madfast Other Vehicles & General Automotive Discussions 10 01-28-2012 11:14 PM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
