Old 05-15-2023, 12:58 PM   #1
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
Drives: 2016 FRS RS2.0 #293
I accidentally pushed the piston out of my rear brake caliper
Any pro tips for getting it back in? Can I grease the piston with permatex brake lube or is that ill-advised?
jkamelo is offline   Reply With Quote
Old 05-15-2023, 01:02 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Should be able to just push it back in. I've always just lubed with brake fluid.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Grady (05-15-2023), jkamelo (05-15-2023)
Old 05-15-2023, 01:42 PM   #3
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
It was sticking and I didn't want to crack the cylinder. I might just line it up best I can, and push it back in with a caliper spreader, and hope it doesn't explode.
Old 05-15-2023, 01:43 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If it's sticking, you need to address that. Is the piston sticking or the slider? How does the seal look?
Ultramaroon (05-15-2023)
Old 05-15-2023, 02:22 PM   #5
jkamelo
[jay-kuh-meh-low]
jkamelo's Avatar
The piston was sticking and didn't want to go back in. The seal looks completely fine.
Old 05-15-2023, 03:41 PM   #6
The cylinder bore and piston should be spotless. The piston must be perfectly lined up with the bore when inserted. Any misalignment will cause it to jam/bind. Don't force it!
NoHaveMSG (05-16-2023)
Old 05-15-2023, 09:02 PM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Aren't you the lady's man.
The Following 3 Users Say Thank You to blsfrs For This Useful Post:
NoHaveMSG (05-15-2023), Racecomp Engineering (05-17-2023), Ultramaroon (05-15-2023)
Old 05-17-2023, 01:12 AM   #8
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Crack the bleeder valve while you push it back in. That way you aren't fighting air or brake fluid
If it's aligned properly and in good working order, you should be able to push it with just your hands
EndlessAzure is offline   Reply With Quote
The Following 5 Users Say Thank You to EndlessAzure For This Useful Post:
blsfrs (05-17-2023), NoHaveMSG (05-17-2023), Ohio Enthusiast (09-14-2024), Racecomp Engineering (05-17-2023), Ultramaroon (05-17-2023)
Brembo Gran Turismo 2 Piston Rear (GT) brake system gtpvette Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-12-2020 06:47 PM
OEM Brake Caliper Piston Size Butterballz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 08-12-2019 11:07 PM
Rear brake caliper banjo bolt size? ChrisD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-22-2016 07:51 PM
Front Brake Caliper Piston Rebuild? smbstyle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 10-17-2013 06:18 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
