Drives: '23 BRZ
Tracking with ABS fuse removed?
Me and a bud are considering this for next time trial event. Rules for classification give -1 point for disabling factory ABS, equivalent to -42 lb. IMO it's a stupid rule but thinking of taking advantage! He has a 2013 BRZ, mine is 2017 PP. Both have the same two ABS fuses. FWIW I ran without ABS (bad sensor) in my '01 S2000 for years and never had any problems. Only concern here is if brake bias without ABS is overly rearward...
What do the experts say?! |
#2 |
Find somewhere else to shave -42lbs
Kyle H. - #89 STX
#3 |
Drives: 15 ZN6, 97 NA8, 87 AE82, 78 MX32
Only one way to find out...
| The Following User Says Thank You to gkubed For This Useful Post: | ZDan (07-01-2020) |
#4 |
Rust bucket enthusiast
Practice without it for a while first. It's not the same car to car.
Did you do HPDE with no abs in your s2000? |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | ZDan (07-01-2020) |
#5 |
Drives: '23 BRZ
Yup, trying it should be straightforward enough. Would be nice to know what to expect in advance though, particularly if something simple like staggered pads might be required if there's too much rear bias without ABS. That's what some said about the S2k though and I had no problems with it at the track or on the street, even in the snow.
#6 |
Drives: '23 BRZ
Also be good to know whether to pull both fuses or just one...
#7 |
Drives: 2017 BRZ w/PP
doesnt long press on the 2017+ disable abs?
#8 |
I don't see in what way, if any, this is a good idea.
Intentionally removing ABS is asking for flat spotted tires, an off, something. Find somewhere else to remove an equivalent of -42 lbs. I know while I don't intend to hit ABS, it happens, and it saves from a lockup. It's honestly such a bad idea...of all places to save -42 lbs this is the last place, IMO. But, you do you
Kyle H. - #89 STX
#9 |
Drives: '23 BRZ
#10 | |
Drives: '23 BRZ
Purpose isnt to save 42 lb. but rather to allow me fren to run in my TT class. But if it works out ok I might get a 5-lb Li battery to take advantage of admittedly dumb rule that rewards this... Last edited by ZDan; 07-01-2020 at 01:18 PM. |
| The Following User Says Thank You to ZDan For This Useful Post: | soundman98 (07-01-2020) |
#11 |
Drives: Miata
#12 |
#13 |
Drives: BRZ 2017 Pure Red, MT
#14 |
Drives: 2015 Subaru BRZ Limited DGM
Other way around
| The Following User Says Thank You to gcranston For This Useful Post: | ZDan (07-02-2020) |
| Dashboard fuse box - mini fuse removal | airrick | Electronics | Audio | NAV | Infotainment | 0 | 10-25-2019 06:05 PM |
| Removed | createluck | Wheels and Tires | 6 | 02-02-2016 12:37 PM |
| REMOVED | Chimera | Audio/Visual, Electronics, Infotainment, NAV | 1 | 06-28-2014 11:48 AM |
| removed | Fast_Freddy | DIY (Do-It-Yourself) Guides | 11 | 11-02-2013 07:46 PM |
