Drives: GT86 DGM
Knocking after lowering *Solved, swaybar endlink*
Just put on my Eibach Pro springs. The springs settled nicely in the seats, and I went over every bolt when putting them on. Everything seemed tight when I put it on, but going over bumps I get knocking in all four corners.
Any tips to where I can go looking? Edit: Turned out to be a loose swaybar endlink. I had loosened it to get better access, forgot to tighten it back up.
#2 |
Drives: 2005 Toyota Camry
You didn't tighten your top strut nut enough.
-alex |
#3 |
Drives: Toyota Skyline Type-R
Yeah esp the middle nut
#4 |
Drives: GT86 DGM
Hm... What torque should I use? I used the guide DarrenDriven made. Maybe my torueqrench is a little low...
I'll go over them again. Luckily they are easy to come by. :-) |
#5 |
Howdy!
Drives: Party ST, Classic Mini
Whatever you tighten them to, make sure you check it while the car is in the air and on the ground. It will make a difference.
#6 |
Drives: GT86 DGM
ok, I will! Thanks!
Anyone know what torque the manual says to use? And when? |
#7 |
41 ft-lbs I believe is the torque required for the strut top nut.
You'll need to use a pass-through torque wrench (if you can get one) and an allen key to hold the strut body. Check all your other fasteners to ensure they are still tight. One that got me worried was the sway bar endlink nut. I used an impact gun on the nut to get it tight, but it ended up backing out a week or so later causing a heinous noise. Went back with a pass-through socket wrench and allen key to tighten it up and all is well. |
#8 |
Drives: FR-S Whiteout
Check your tire clearances to the spring and perch. I get noises from my 245's rubbing against the spring when the wheel is turned. 45mm offset with 5mm spacer so effectively 40mm along with -2.6* camber.
#9 |
Drives: 2013 Raven FRS 6MT
could be your swaybar endlinks
#10 |
Drives: GT86 DGM
Thanks for all the tips, guys!
I'll get some deep pass-through wrench and an allen key to check the strut top nut. That one I just used my impact gun until it seemed to be tight, but could be it just tightened up enough to turn the strut axle. I'll also make sure to check the endlinks again. |
#11 | |
#12 |
Drives: GT86 DGM
How does fastening a nut to an axle blow the struts? I'm just curious.
Sent from my GT-N7100 using Tapatalk |
#13 |
These struts are extremely sensitive to being spun. If you had looked at any of the DIY spring/strut install threads on this forum, you'd have known from the beginning that many users have reported using an impact gun on the strut top nut has caused their strut to make noise, leak, and ultimately need to be replaced.
You can start diagnosing by tightening the strut top nut the correct way, but if it's still making noise, look for tell tale signs of blown struts - hydraulic fluid leaking, struts compressible by hand, etc. |
#14 |
Drives: GT86 DGM
Will do!
I can't remember Darrendrivens how to mentioning that, but I may well have missed it Edit: just checked, the guide I read specifically mention impact as a useful tool for the top nut Sent from my GT-N7100 using Tapatalk |
| Knocking sound | Moe23 | Issues | Warranty | Recalls / TSB | 80 | 04-18-2019 08:09 PM |
| Knocking doesn't sound good :-(. | TheMarkness | Issues | Warranty | Recalls / TSB | 41 | 02-04-2015 10:38 PM |
| Knocking on Startup? | 636 | Issues | Warranty | Recalls / TSB | 17 | 02-03-2014 07:18 AM |
| Knocking/Rattle on start up. | jimbobrand | Issues | Warranty | Recalls / TSB | 18 | 01-13-2014 11:34 AM |
| Knocking sounds from lowering springs? | bbaik | Issues | Warranty | Recalls / TSB | 7 | 03-07-2013 11:50 PM |
