Old 04-01-2013, 08:59 PM   #1
NickFRS
Drives: 2013 Asphalt FRS
Perrin LWCP tensioner wabble
Is this normal? Mine will make a knocking noise 20% of the time while it's going crazy. Anyone know what may cause this? The shop I go to simply thinks I have a bad Pulley.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 04-01-2013, 09:09 PM   #2
M1K3
M1K3's Avatar
Drives: vrooom...
You should definitely take a look at this thread: Crank Pulley Warning
M1K3 is offline   Reply With Quote
Old 04-01-2013, 09:29 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
I have the stock pully and my tensioner moves around a lot at idle. Not enough to make a knocking sound though.
1974 TA22 Celica
2013 86 GT
Old 04-01-2013, 09:40 PM   #4
Yruyur
Yruyur's Avatar
My first car I had a wobble but my new one does not with the same pulley. I would follow that link up above. I'm thinking I may have pulled mine out a tad on the first car and never knew it.
Old 04-01-2013, 09:52 PM   #5
NickFRS
Thx guys the more input the better! Keep it coming. Also sorry if this is in the wrong section. Would be cool to get a post from the Perrin guys. @PERRIN_Mladen @PERRIN_Jeff
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Old 04-01-2013, 09:58 PM   #6
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
no wobble on the new car??insane
Huehuecoyotl is offline   Reply With Quote
Old 04-02-2013, 11:54 AM   #7
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Nick,
Lets just get you a new one that has been tripled checked. We can then get yours back and check to see what was wrong with it. The problem does not sound like the normal wobble associated with the part so lets get it taken care of.
PERRIN_Mladen is offline   Reply With Quote
Old 04-02-2013, 01:09 PM   #8
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
It's normal for the bolt head to not look centered when the engine is on, since the bolt head isn't centered on bolt exactly. It's also normal for the tensioner to be moving too when the car is idling, but it's not normal to get any type of knocking sound. Hopefully we can figure it out!
PERRIN_Chris is offline   Reply With Quote
Old 04-02-2013, 08:23 PM   #9
NickFRS
Perrin rocks! hope all this fix's the issue.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
Need V-belt tensioner torque value... cobrabyte Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 10-10-2014 10:47 AM
Let there be NO DOUBT: Non Resonated PERRIN> Resonated Perrin HP gmookher Engine, Exhaust, Transmission 78 09-11-2013 10:42 AM
driver belt tensioner Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 3 07-10-2012 05:44 PM
