Hood lift at high speeds
Dunno whether this comes up much butI've heard of this issue several times already:
Upon reaching more "interesting" speeds, the hood starts to lift slightly. Well, it's still hinged safely in place but when it happened to me on a particularily even strip of highway I got shaking from that interference and driving above that speed neither felt reassuring or safe anymore. I guess it started at about 180km/h. Now I know that I'm kinda spoiled when it comes to anything aerodynamics-related but this is just wrong. Knowing the physical background of this phenomenon I want to try and fix it. Before carving vent ducts into the hood I'd favor opening those sharkfin side panels the BRZ generously already provides. I'm thinking of opening the fake plastic... "mesh"... , exchanging it w/ the real thing and then installing a kind of tunnel to the engine compartment. I hope that this will relieve the difference in air pressure created by air being forced into the engine compartment. That should equalize the pressures at least enough th make 200km/h w/o trouble. However, does any1 know whether it'd be possible to create such a venting system? I don't know how the area behind the side skirts looks so any insight would be appreciated. Also, if you've already solved said issue, let me know. |
| The Following User Says Thank You to Basti For This Useful Post: | R2RO (03-01-2013) |
#2 |
VTEC just kicked in, yo!
Drives: World Rally Blue BRZ - 6MT
I've never heard of this issue before, but I'd imagine I'd have a heart attack if my hood opened at high speeds and slammed into my windshield.
#3 |
I guess that'd be no problem as you'd probably crash right afterwards
![]() However, as I said, the hood's still locked, its very light weight makes it susceptible to lifting (the same principle as on airplane wings) and, in my experience, messes up handling quite a bit. Actual lift is about 5mm tops. In a local forum this topic has already been discussed, the aptitude to fix it is generally low due to the small number of owners. |
#4 |
Drives: '13 BRZ in WRB--let's mod!!!
You mean our cars go fast enough for that to happen? Lol
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. |
#5 |
easily, really.
I never had the problem with my '95 Honda even at higher speeds but then again, the hood weighted about 4 times as much. |
#6 |
We've had our car at 140+mph (racetracks!
) but I'm looking at the track, so I haven't noticed any hood lift...
| The Following User Says Thank You to CSG Mike For This Useful Post: | track_warrior (02-18-2013) |
#7 | |
Drives: WRB BRZ Sport Tech
#8 |
Sarcastic SOB
In Ontario (Canada) if you drive 180 km/h you might as well just give your car to the police since they will seize it when you are stopped, plus up to $10,000.00 fine for "stunt driving".
Even on the unrestricted stretches of autobahn, is this really the car to be burying the speedometer needle?
#9 | |
Drives: Attitude
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | wichiewichie (02-07-2013) |
#10 |
ZC6A2B82KC7J
Drives: 2002 WRX
Try driving a WRX... with the hood scoop sticking out into the air it flops around like one of those crazy inflatable dancing car dealership guys. I don't think it's anything to worry about. Do you have a front lip spoiler? That would probably create enough downforce to get back the high speed stability, or even a downforce generating rear spoiler. When I put an STI wing on my WRX I noticed it felt a lot more stable at high speeds.
| The Following User Says Thank You to Spaceywilly For This Useful Post: | mangostick (02-06-2013) |
#11 | |
Drives: Four wheels, two seats, etc
But as for the side vents I think it would actually make a difference, for some cooling too. It's an idea I've been toying with as well. |
#12 |
#13 |
Drives: Asphalt AT
| The Following 2 Users Say Thank You to Asphalt~86 For This Useful Post: | Black Tire (02-07-2013), continuecrushing (06-19-2013) |
#14 |
Drives: Attitude
The whole car's a bit floaty... that speed requires more aero and less complaint bushing IMO. A properly made diffuser (hint: I know some people makin' some, eventually) will help the floatiness in the rear.
| Where to Lift with Two Post Lift? | Don Ivey | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 08-18-2022 08:51 AM |
| Speeds at each gears. | mickey177 | Engine, Exhaust, Transmission | 10 | 08-25-2016 06:40 PM |
| Wind/road noise at highway speeds? | Kieranz | BRZ First-Gen (2012+) — General Topics | 20 | 06-13-2013 10:11 AM |
| Post you speeds for fun... | seven | Off-Topic Lounge [WARNING: NO POLITICS] | 48 | 01-27-2013 07:37 PM |
| RedLine Tuning Hood Quick Lift | tonystewart | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 12-15-2012 12:28 PM |
