Old 03-06-2018, 11:38 PM   #1
kazmone1
Drives: Car
OFT Stage 2 but still getting O2 Sensor CE
Hi, I installed a UEL on my 14 FRS, and flashed the ROM with an OFT Stage 2 UEL ots tune. Everything was good at first, but over the last 2 weeks I have gotten four different check engine lights all pointing to issues with the second 02 sensor.
Things i have done:
Used OEM new gaskets on all exhaust components for header and overpipe.
Replaced 02 sensor
Verified torque on header to head
Verified torgue on header to overpipe
Drivetrain Mods:
HKS airfilter
1320 headers
1320 overpipe
stock front pipe
Manzo M2 catback
I was under the impression that the stage 2 tune eliminated the 02 sensor reliance. Is that not the case? Anyone else have this problem?
kazmone1 is offline   Reply With Quote
Old 03-06-2018, 11:46 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I don't have my laptop in front of me and am kinda drunk right now bu go to CEL's and see if p0420 is enabled.
Old 03-07-2018, 02:43 AM   #3
skogs
Drives: GT86 2013
I had the same issue. Just email a copy of the tune file you are using to customer support at openflash. They will fix it
skogs is offline   Reply With Quote
Old 03-07-2018, 05:33 AM   #4
steve99
Drives: FT86
If your getting cel codes relared to rear o2 sensor then it likely the sensor was damaged during header install
Or you may have exhaist leaks do you have ltft over 10%.
If you intake is stock then its very unlikly its a tune problem .
List of codes would help
Old 03-07-2018, 05:45 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
what are the CEL's specifically. List them.
guybo is offline   Reply With Quote
Old 03-07-2018, 10:39 AM   #6
kazmone1
Drives: Car
Error codes are p0139, p2097, p2098
The o2 isn’t damaged as it’s a brand new 02 sensor. Getting codes a day after install. Getting codes on other o2 as well.
I just reflashed my ecu with uel stage 2 again. I’ll see if maybe a bad flash
Old 03-07-2018, 11:19 AM   #7
Teseo
Drives: frs
Try to undo everything
Old 03-07-2018, 11:38 AM   #8
kazmone1
Drives: Car
Here are two data logs. One before i reflashed and it was running like a dog (but no check engine lights). One after i just reflashed.
Old 05-18-2018, 12:47 PM   #9
kazmone1
Drives: Car
Bump. Still having the problem. Have replaced the o2 and new gaskets. Nothing keeps it from coming back.
Old 05-18-2018, 01:09 PM   #10
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Looks like the tune did not disable the CEL. Reach out to Shiv and have him look at this.
Old 05-18-2018, 02:33 PM   #11
guybo
Huge E85 fan!
guybo's Avatar
the tune disables the P0420, that's it. It does not effect the operation of either O2 sensor. One of them is not even an o2 sensor, it's an Air Fuel sensor.
Just because your O2 sensor is new, does not mean it is working right. Get it tested at a shop that can look at the output of the sensor. Also, it could be a case of damaged wiring.
Old 05-23-2018, 04:52 PM   #12
skogs
Drives: GT86 2013
I had the exact same problem, turned out to be an issue with the tune. Openflash modified the tune and now it works.
Old 05-23-2018, 08:40 PM   #13
steve99
Drives: FT86
which 02 did you replace those codes are for rear 02. not the front 02.
If you removed the rear 02 completly that wont work unless you modify tune. the standard tunes just disable the cat converter check function, if you complety remove rear 02 you need to make other adjustments to tune
Old 05-23-2018, 09:01 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What calid are you using?
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help Johnders2586 Issues | Warranty | Recalls / TSB 9 04-04-2023 03:32 PM
Windband sensor location with OFT stage 2 randomthoughts Software Tuning 2 04-02-2017 04:36 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
