Old 05-14-2014, 07:20 PM   #1
Michael Blue
Drives: 1998 Audi A4 Quattro Sport 30v
Lowering options with (near) stock rates and adjustable dampers?
Hey there.
Does anyone know of any lowering options with (near) stock rates and adjustable dampers? Really like how the BRZ rides but want to lower it for AutoX, occasional track days.
Need adjustable dampers and recommendation for good swaybars.
Thanks!
~M
Michael Blue is offline   Reply With Quote
Old 05-14-2014, 11:34 PM   #2
wparsons
wparsons's Avatar
Why do you want to lower it for autox and track days? It handles just fine at stock ride height, and when you're pushing hard enough to need upgraded suspension you'll want higher spring rates.
flickr
was385 (05-17-2014)
Old 05-15-2014, 08:25 AM   #3
celica73
Lowered at stock or near stock spring rates will result in lots of time on the bumpstops, I don't think that is the droid you are looking for.
The Following 3 Users Say Thank You to celica73 For This Useful Post:
Racecomp Engineering (05-15-2014), was385 (05-17-2014), wparsons (05-15-2014)
Old 05-15-2014, 03:42 PM   #4
8R6
8R6's Avatar
Drives: FRS
btw, setting up a car for auto-x and road track are two complete separate things. you should pick one and then modify with whatever is a better fit for that.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
wparsons (05-17-2014)
Old 05-15-2014, 04:19 PM   #5
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
If he's not trying to compete there isn't much harm in trying for a balance.
If you want to do a jack of all trades, I'd aim for something with squarish spring rates and high quality dampers. Adjust sway settings to help it rotate more or less depending on the event. Not perfect, but you should be able to find a setup that does very well at everything you've mentioned.
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
Old 05-17-2014, 01:22 PM   #6
Michael Blue
This sums up what I'm looking for nicely.
I'm watching the Bilstein thread closely, but otherwise this describes what I'm after.
Are there any existing kits out there that you would recommend for this kind of setup?
Thanks!
Old 05-17-2014, 01:38 PM   #7
wparsons
wparsons's Avatar
I'd probably go with RCE Tarmacs or Swift Spec R's if you're going to get better shocks at the same time.
flickr
Old 05-17-2014, 08:13 PM   #8
SubieNate
SubieNate's Avatar
Thanks!
What's your budget and are you leaning towards a strut/spring setup or coils?
Cheers
Nathan
Old 05-18-2014, 09:19 AM   #9
Michael Blue
Honestly, just starting to look, so budget is pretty open and I haven't decided on coil-overs or strut/spring. Open to all possibilities.
Thanks!
Stock Sway Bar Rates Tirewarmer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-17-2017 02:27 PM
Rebuilding strut/shock dampers to be firmer than spring rates? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-16-2014 01:23 AM
Suggestion For Those With Rear Adjustable Dampers Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-14-2013 11:19 PM
Best springs to go with stock dampers solidONE Tracking / Autocross / HPDE / Drifting 15 07-01-2013 02:36 AM
