Old 06-14-2013, 11:15 AM   #1
Tirewarmer
Stock Sway Bar Rates
Anyone have the rates for the stock 18mm Front 14mm rear in lbs/in sitting around that they could post here for me?
I searched the forums and couldn't find the baseline number for the OEM bars.
Thanks,
Joe
Tirewarmer is offline   Reply With Quote
Old 07-07-2013, 05:14 PM   #2
FRSGeek
Drives: UltraMarine 6 Spd MT
I am interesting also, as I am wondering what changes to F/R could be used on 19mm F/ 16mm R from Perrin, they are adjustable and for me, 245/35 or 255/35 x 18's @ 45 offset would change the loading the sway-bars have to control. If this highjacks Joe OP question let me know and I'll move it. But it seemed like we both can get answers.
Thanks,
Joe
FRSGeek is offline   Reply With Quote
Old 07-09-2013, 01:31 PM   #3
FRSGeek
Ping for the suspension experts.
Old 07-09-2013, 02:04 PM   #4
Racecomp Engineering
140 lbs/in front
113 lbs/in rear
EDIT: not quite true
- Andy
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
DAEMANO (08-17-2017), Tirewarmer (07-09-2013), TouchMyHonda (01-07-2014), wparsons (08-17-2017)
Old 08-14-2017, 03:23 PM   #5
gtpvette
Drives: 2015 FRS - FFR GTM
Zombie thread back from the dead.
Andy,,,
I wanted to ask would 2015 FRS still have 140lb Front Swaybar rate?? With RC Yellow Springs,,, would a stifffer bar be better???? If so,,, how much stiffer in LBs?? I'll need to do a custom bar with the swap I'm doing,,, no room for the OEM bar.
Thanks!!!!
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 08-17-2017, 11:08 AM   #6
Andy,,,
Thanks!!!!
All depends....in general most will improve with a slightly stiffer front bar than stock. 20mm to 22mm is the sweet spot but it depends on the rest of the car. I wouldn't do a 22mm without a larger rear bar and even with a 20mm I would recommend a slightly larger rear bar with our RCE Yellow springs. If you have coilovers you can change spring rates to get a desired balance.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
DAEMANO (08-17-2017), venturaII (08-17-2017)
Old 08-17-2017, 12:52 PM   #7
gtpvette
- Andrew
Thank you sir! I'm looking at a Speedway Engineering splined bar so I'l shoot for 140lb min with an adjustable arm for more if needed/wanted.
The Following User Says Thank You to gtpvette For This Useful Post:
Racecomp Engineering (08-17-2017)
Old 08-17-2017, 01:27 PM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
- Andrew
I have an 18/22 combo on otherwise stock '13 suspension (FRS, crash bolts and a semi-aggressive alignment) and I love the feel. Reduces lean a bit, without really changing it's behavior. The car turns in nicely at low speed and is very neutral on the track, without feeling too twitchy or unstable in faster sweepers.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
FS: SOCAL: STOCK 14mm rear sway bar mr. slim Brakes, Suspension, Chassis 1 05-13-2013 02:50 AM
Stock Sway Bar Sizes On FRS? gbgracer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 04-25-2013 09:22 PM
Stock springs and sway bars Spencer Brakes, Suspension, Chassis 3 04-25-2013 09:41 AM
FS: Aftermarket tail lights, stock sway bars, etc Zangetsu Australia Classifieds 19 02-16-2013 01:34 AM
WTB: Stock WRX 16mm Rear Sway Bar NYC BRZ Cars for Sale/Trade 3 09-01-2012 06:36 PM
