Old 09-25-2012, 01:28 AM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Do aggressive offsets cause more debris to kick up into the paint?
Specifically, if the rim is evenly flush with the fender, that means the rest of the tire will protrude past the body (since the body curves in as you look down from the fender). So this increases chances of accumulating more rock chips along the side of the body, no? Anybody have firsthand experience with this?
Old 09-25-2012, 01:38 AM   #2
SilverSkyline210
SilverSkyline210's Avatar
Drives: WRB BRZ
yes, i have experienced this, especially because of autumn all these leaves all over the road, and when it rains, the whole side of my car was covered in mud and leaves no paint chips though, i guess cause the angle the debris hits is shallow so not too direct, you can hear it when you run over some small gravel or sand all the light taps and knocks on your car body
SilverSkyline210 is offline   Reply With Quote
Old 09-25-2012, 01:38 AM   #3
speed6sam
Drives: SWP BRZ Limited 6 Spd
you will not necessarily get more rock chips but the side of the car will get dirty a lot more in the rain than normal as all of the dirty water is slung up the side of the car
speed6sam is offline   Reply With Quote
Old 09-25-2012, 01:51 AM   #4
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
that can happen especially if the tires are sticky, so road debris and whatever you run over on the road can get flung onto the side of your car possibly causing rock chips. mud flaps can help remedy this.
Old 09-25-2012, 02:15 AM   #5
cnk
Drives: '13 DGM BRZ Limited
I picked up a set of Rally Armor mud flaps for just this reason. I hate it when you spend all this time cleaning your car and the first rain that it sees results in dirt getting kicked up all over the side of the car.
Old 09-25-2012, 03:58 AM   #6
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I can assure you yes, plenty of my subarus & my old gtr experienced it due to sticky rubber... I actually went ahead and now have xpel film on the fr-s in areas that it seems to kick up as a precaution. Similar to the way Evo X's & GR STi's have from the factory on their fender arches/flares.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
The Following User Says Thank You to OmarGC For This Useful Post:
switchlanez (09-25-2012)
Old 09-25-2012, 07:35 AM   #7
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Yes the car does get dirtier with aggressive offsets. I went with the rally armor as well. Pictures here http://www.ft86club.com/forums/showp...0&postcount=71
F1point4 is offline   Reply With Quote
Old 09-26-2012, 11:03 PM   #8
RAYSSPL
Drives: bicycle
I'm running some stupid wide and low offset wheels on my MR2 Spyder and I don't notice much of a difference. Still clean and no rock chips. Although I'm aware that it is very possible to have this problem happen for others.
I'm running 15x9 +36 and 15x10 +25 on the MR2 Spyder, btw.
RAYSSPL is offline   Reply With Quote
OEM Paint speedyboy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 09-21-2012 02:03 PM
So, I hit some flying road debris today... eriktherod Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 26 06-26-2012 07:28 PM
paint restoration : Subaru WRX - bringing the paint back to life brianc Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 06-25-2012 02:23 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 11:47 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
