Old 10-03-2024, 12:33 AM   #1
SOLID2223
Drives: Brz
FLAT FOOT SHIFTING=ROLLING ANTILAG
Hello looking for some tuning experts opinions with my idea. I recently had a theory to use the FFS(flat foot shifting) feature integrated into the ecutek software as rolling anti lag. To my understanding for FFS to engage throttle must be at 100% and clutch has to be depressed. I was thinking about using a secondary switch for my clutch switch”tricking” the ECU into activating the FFS feature WITHOUT the clutch depressed. Hence creating”rolling anti lag). Yes I’m aware this isn’t true anti lag however it could be useful in building boost for stock motors while rolling. My main concern is the engine load would differ greatly because during FFS there is no load due to the clutch being depressed. So if the FFS feature were to be used as anti lag without a depressed clutch would the feature still function as designed?
SOLID2223 is offline   Reply With Quote
Old 10-03-2024, 01:44 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
A couple of years ago, my tuner left FFS engaged. What is did was cause my engine to bog down as I was revving up and preparing to shift because I unconsciously put a light pressure on the clutch pedal.
A datalog showed that FFS dropped the ignition timing to 0* when the engine was over 4500 rpm and my foot touched the clutch.
So, in my nonexpert opinion, I don't think FFS will do what you are seeking.
Old 10-03-2024, 02:02 PM   #3
SOLID2223
Drives: Brz
Did the datalog show the rpm holding or increasing during the time FFS was active
Old 10-04-2024, 11:07 AM   #4
blsfrs
blsfrs's Avatar
My butt dyno and the datalog showed rpms holding. It was like a governor or rev limiter kicking in.
Old 10-04-2024, 01:37 PM   #5
SOLID2223
Drives: Brz
So my theory was correct it will hold the rpm if the car is still in gear without the clutch depressed.
The Following User Says Thank You to SOLID2223 For This Useful Post:
blsfrs (10-04-2024)
Old 10-09-2024, 12:56 PM   #6
blsfrs
blsfrs's Avatar
I was pondering your idea. You may not have to install an extra switch. The clutch switch will "activate" with enough pressure to move the pedal a pube hair's distance. You could experiment by turning the cruise control off by touching the clutch pedal.
Old 10-09-2024, 06:09 PM   #7
SOLID2223
Drives: Brz
I understand your idea however your clutch assembly already has preload and barely pressing the clutch could cause abnormal damage to the clutch pressure plate and throw out bearing. That’s why people say don’t ride the clutch. Along with slippage from the friction disc.
blsfrs (10-10-2024)
Old 10-10-2024, 09:39 AM   #8
blsfrs
blsfrs's Avatar
You might be surprised how little pressure it takes on the clutch pedal to active the clutch switch. It's not enough to cause any problems with the clutch.
The Following User Says Thank You to blsfrs For This Useful Post:
Ultramaroon (10-10-2024)
Old 10-10-2024, 10:01 PM   #9
SOLID2223
Drives: Brz
I will try it out and see how sensitive the switch is and I will go from there
blsfrs (10-11-2024)
OFT's Flat Foot shifting question Swole Software Tuning 2 03-01-2019 07:31 PM
Flat foot shifting won't let me redline! Dr. BRZ Software Tuning 2 03-27-2018 02:40 AM
racerom flat foot shifting ft86me Engine, Exhaust, Transmission 10 07-25-2013 04:02 PM
EcuTek RaceRom Flat Foot Shifting ! Visconti Engine, Exhaust, Transmission 79 11-14-2012 10:36 PM
