Old 02-26-2023, 06:01 PM   #1
Humphrey
Drives: 2014 Subaru BRZ (JSRC)
ExtremeContact DWS06 Plus Traction Issues
I purchased these tires new a long with 17x9 Gram Lights. After installation onto my car from Big Brand Tire the car feels much much more floaty.
Switching from 17x7 rims and single A traction tires to double A traction tires I expected to gain confidence on turns. Now when taking turns on the freeway I have to be careful and traction control has saved me a few times.
I've found people saying the tires need to be broken in. I'm wondering if there is truth behind this and/or if anyone else has had a similar experience. Or is this what I should expect from the new setup below?
Switch was:
Stock rims (215/45/R17 All Season Single A Traction)
to
17x9 Rays Gram Lights (245/40R17 ExtremeContact DWS06+)
Humphrey is offline   Reply With Quote
Old 02-26-2023, 10:44 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I didn't have the Plus versions, but I did have the regular DWS06 a few years back on my FR-S and they do tend to understeer a bit. I still felt planted and could handle most turns, but they were an all-season after all.
MS, CSCS, TSAC-F, CPT
Old 02-27-2023, 12:03 AM   #3
glhs386
Drives: 2014 FR-S Monogram
Tire traction ratings are for wet surfaces, they have no direct correlation to grip on dry pavement. I had a set of Yokohama A032Rs back in the day with a C traction rating, I assure you they had plenty of dry grip (for the time). You bought 560 treadwear all-seasons with squishy sidewalls designed for comfort. Hate to say it, but that's the wrong type of tire if your goal is handling and performance. There's really no comparison with a 200-300 treadwear summer tire.
glhs386 is offline   Reply With Quote
The Following User Says Thank You to glhs386 For This Useful Post:
Desertnate (02-27-2023)
Old 02-27-2023, 04:25 AM   #4
Humphrey
I agree summer tires will preform much better but I’m running Good year eagle sports on my automatic BRZ with single A traction but still 560 tread wear and the car handles much much better.
Old 02-27-2023, 01:30 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Tread squirm and mold release are real things that affect brand new tires that will take a couple hundred miles to subside.
But yeah 500+ tw tires aren't going to be ideal for grip/handling.
Originally Posted by humfrz
I'm old and lazy
The Following 3 Users Say Thank You to Clipdat For This Useful Post:
Capt Spaulding (02-28-2023), DarkPira7e (02-27-2023), RToyo86 (02-28-2023)
Old 02-27-2023, 01:47 PM   #6
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
What is your tire pressure? 255s feel really bad if you have too much tire pressure. Also what everyone else said.
Old 02-27-2023, 02:13 PM   #7
DriftMethod
Drives: '20 BRZ Ltd PP
Worn tires with reduced tread (within reason) can have larger contact patches. And as already mentioned, you'll have less tread squirm than on new tires. I think Continental has a 60 day trial warranty, so if they really aren't working, you might be able to trade them for a different Continental tire (might have to go with summers though).
DriftMethod is offline   Reply With Quote
Old 02-27-2023, 04:55 PM   #8
Desertnate
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
Mold release on a new set of tires is something people rarely think about. I've had some really good tires feel downright scary in the rain simply because they were brand new. After they got some miles in them, everything was fine. In several instances there was a visible change in thread surface of the tires after 200-ish miles.
I had great luck with DWS06 tires. They aren't summer tires when it comes to grip, but they were still pretty competent. I've even several people running them on their cars at our local autocross and at least one of them put up numbers which were better than others running summers or 200TW tires. If you drive them right, they should hold up pretty well.
Desertnate is offline   Reply With Quote
The Following User Says Thank You to Desertnate For This Useful Post:
soundman98 (02-27-2023)
Old 02-28-2023, 10:31 AM   #9
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Ride a motorcycle for any length of time and scuffing the release compound off new tires will move up your “to do” list.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
Desertnate (02-28-2023), Wally86 (02-28-2023)
Old 02-28-2023, 12:03 PM   #10
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Always chill out for the first 100 miles
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
Racecomp Engineering (03-02-2023)
Old 02-28-2023, 12:33 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
....or two laps.
The Following 5 Users Say Thank You to Pat For This Useful Post:
Capt Spaulding (03-01-2023), Desertnate (02-28-2023), NoHaveMSG (03-03-2023), Tatsu333 (03-01-2023), Wally86 (02-28-2023)
Old 02-28-2023, 01:54 PM   #12
Desertnate
Spelling Impaired
I use one tank of gas in normal commuting if the timing is right. More than 100 miles and probably much longer than needed, but foolproof and easy to remember in case I didn't look at the mileage when I left the tire shop.
Wally86 (03-01-2023)
Old 02-28-2023, 03:18 PM   #13
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Normal, the Conti DWS06(or + variant) and even their ECS or ECS02 tires are all kinda "floaty" and that makes them ride well and drive nicely but they're definitely not precise.
Old 03-01-2023, 12:16 AM   #14
Capt Spaulding
Persona Non Grata
Wow. I need to broaden my tire horizons. I’ve been on ECSs for a couple of years and would not have associated floaty with them.
I just don’t wear tires out fast enough to play the field.
extremecontact, tires, traction, wheels
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 05:32 PM
traction control issues mvanessa816 Scion FR-S / Toyota 86 GT86 General Forum 2 04-06-2020 12:06 AM
Traction Control Issues Chronology Tracking / Autocross / HPDE / Drifting 22 04-11-2017 06:07 PM
(SOLD) Continental ExtremeContact DWS06, 255/35/18 Michael Wheels and Tires 2 07-02-2016 06:56 PM
Abs and Traction Control Issues Phothiraj BRZ First-Gen (2012+) — General Topics 4 07-23-2015 11:51 AM
