Old 01-11-2023, 01:09 PM   #1
Pikachu777
Pikachu777's Avatar
Drives: 2015 Scion FRS TRD Edition
Angry TAIL LIGHT FUSE KEEPS BLOWING
Hello everyone ,
My taillight fuse keeps blowing and I’ve reached a roadblock . I know I have a short somewhere but I have no electrical experience and wanted to see if I could get some help before paying a mechanic… as it may be something I’m overlooking. I want to mention that I’ve disconnected the tail lights and it still blows . I’ve also took both fuses out for the headlights and it still blows . So check this out … when I unplug the actual headlight switch/lever the fuse does not blow . But as soon as I plug it back up it blows immediately. Also want to mention this all started after a bad storm .All advice is appreciated
Pikachu777 is offline   Reply With Quote
Old 01-11-2023, 02:01 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Sounds like you got water where it shouldn't be. Do you know how to use a multimeter?
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Tcoat (01-12-2023), x808drifter (01-12-2023)
Old 01-11-2023, 05:36 PM   #3
Pikachu777
Pikachu777's Avatar
Unfortunately no , but I’m about to learn . Or at least find someone who does
Old 01-12-2023, 09:59 AM   #4
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Like a mechanic...
Old 01-12-2023, 03:42 PM   #5
Tokay444
Find the short and fix it.
The Following User Says Thank You to Tokay444 For This Useful Post:
x808drifter (01-13-2023)
Old 01-19-2023, 02:48 PM   #6
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Might be a grounding issue. Good luck!
MJones_RB is offline   Reply With Quote
Old 01-19-2023, 03:26 PM   #7
Falkon240
Falkon240's Avatar
Drives: 2013 FRS
What aftermarket parts have you installed on the car? Suspension, interior, exterior, lighting, etc.
Chances are when you or the installer put a part in you pinched a wire and opened the wiring insulation grounding it to the chassis.
Go back over your parts and make sure nothing has been pinched or damaged.
The reason I say this is I installed a rear bumper on another one of my cars and pinched the license plate harness on the bumper support grounding it out. The circuit closure was so bad that the wires heated up and melted the insulation around the entire tail light harness.
My gas tank level sensor light turned on amongst other things because of this short circuit.
IG
2013 Scion FR-S
2022 Chevrolet Colorado ZR2 Bison
1998 Nissan 240SX KA24DET
Falkon240 is offline   Reply With Quote
Old 01-21-2023, 02:53 AM   #8
Bubba says to replace the fuse with a large paperclip and stand back and look for the sparks, flame and smoke. There be your short.
(I THINK Babba was kidding)
WNDSRFR (01-23-2023), x808drifter (01-21-2023)
Old 01-21-2023, 07:43 AM   #9
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Have you tried disconnecting the trunk harness?
The 10 amp "TAIL" fuse also powers the license plate lights, not just the tail and side markers. A Bad storm? Maybe you've got license plate bulbs soaking in their juices, or maybe the storm is unrelated and wires are frayed in the hinge part of the harness, that happens often on many makes and models.
If the carpet isn't wet it's not terribly likely that the storm drenched something inside the car.
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
alphasaur (01-23-2023), soundman98 (01-21-2023)
Old 01-21-2023, 07:05 PM   #10
https://www.khanacademy.org/science/...ce-and-voltage
Old 01-23-2023, 10:32 AM   #11
Tokay444
It's definitely the suspension.
Old 01-23-2023, 04:05 PM   #12
WNDSRFR
Drives: FR-S,GTI
I know you're kidding but it would definitely show you where the problems is. And if you hit it quickly enough it might not do that much damage.
The Following User Says Thank You to WNDSRFR For This Useful Post:
humfrz (01-24-2023)
Old 01-23-2023, 04:39 PM   #13
It also might take out other expensive components. Recommend hard pass.
humfrz (01-24-2023)
Old 01-24-2023, 08:39 AM   #14
x808drifter
LMGTFY
Think OP was electrocuted seeing as they haven posted since.
F
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
Falkon240 (01-25-2023), NoHaveMSG (01-24-2023), Ultramaroon (01-24-2023)
blown fuse, electrical issue, taillight
BRZ TAIL FUSE BLOWING 404dare Cosmetic Modification (Interior/Exterior/Lighting) 14 04-13-2023 09:25 PM
Tail Fuse keeps blowing turbowhistle Scion FR-S / Toyota 86 GT86 General Forum 6 10-16-2022 11:39 AM
Tail light fuse keeps blowing Natasha BRZ First-Gen (2012+) — General Topics 6 07-05-2022 07:33 PM
Tail/Fog/Plate light fuse keeps blowing leevanf BRZ First-Gen (2012+) — General Topics 5 09-07-2018 09:09 PM
Running light "Tail" fuse in foot well keeps blowing **Fixed** paintdude258 Electronics | Audio | NAV | Infotainment 0 04-12-2017 04:59 PM
