Old 08-13-2021, 05:04 AM   #1
Peanuts
Drives: 2015 Toyota 86 GTS
Unhappy OEM reverse camera with Aftermarket HU
Hi guys just some context:
I've installed the Pioneer DMH-A4450BT into my 2015 86 GTS, and have everything else working except the OEM camera currently.
I have the following adapter which is meant to adapt the reverse camera into RCA that I can use with my head unit:
https://aerpro.com/apvty04
The problem is it does nothing. I hit the pins in the 4-pin connector with a multimeter and it seems they don't do anything at all? As far as I thought, this should have just been a plug and play adapter
I've had a look around for pin-outs and diagrams and can't find many that even mention this 4-pin plug, except for these adapters. In my stock HU I can see it was plugged in there so I'd assume it does something. Looking at pin-outs for other plugs, it looks like the camera power and video might be in the big 28-pin plug that I don't have hooked up to anything?
Any help would be appreciated as it's the only thing I need to sort out
EDIT: Not sure if I can delete my own thread, but I believe my issues could be caused by not having the reverse signal wire hooked up correctly, which may power the camera and get everything working. I'm going to try see if this is the case tomorrow
Peanuts is offline   Reply With Quote
Old 08-13-2021, 10:07 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
yea, you need the reverse wire connected, or provide alternative power to the camera, and signaling to the head unit to make it all work.
Old 08-14-2021, 02:02 AM   #3
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
IIRC, the OEM camera is six volts, make sure.voltage levels are compatible with your aftermarket system…
I went the other direction- installed a aftermarket camera with my 2013 OEM stereo and it required a relay to source a 12 volt circuit for the camera.
Originally Posted by drewbot
Pull out
nextcar is offline   Reply With Quote
Help with reverse camera melvin_213 Electronics | Audio | NAV | Infotainment 23 05-20-2020 12:23 AM
Need help with installing Camera Source's reverse camera for 2013 FRS Ann13 DIY (Do-It-Yourself) Guides 9 09-30-2019 08:39 PM
Reverse Camera Emissary_of_Pain Electronics | Audio | NAV | Infotainment 5 10-27-2017 11:13 AM
OEM Reverse Camera and aftermarket head unit map26 Electronics | Audio | NAV | Infotainment 0 07-27-2015 10:47 AM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 11:21 AM
