Old 05-14-2021, 12:54 PM   #1
Nitewing1423
Drives: Blue
What’s a good aftermarket double din stereo?!!
Wanna get a really good double din stereo to replace my stock one and algo get rid of the fisheye rear view camera.
Can anyone recommend one that has wireless Apple CarPlay GPS Bluetooth and all those other features??
Nitewing1423 is offline   Reply With Quote
Old 05-15-2021, 03:13 PM   #2
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
There are simply too many choices out there. You need to do as much reading and research as you can to determine your exact needs and how you want to integrate your new head unit into your twin's sound system. There is a factory amplifier in the trunk that you may or may not want to use that gets its signal from the front dash speakers, filters out the high frequencies, and powers the door speakers.
Start here,
https://www.crutchfield.com
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 05-16-2021, 12:35 PM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Wanna get a really good double din stereo . . .
Welcome to the forum Nitewing1423!
Just an FYI: The factory head unit is not a Double DIN size. It is identified as a "200mm nose piece". This is the diagonal measurement of the dash opening. It is the same height as a Double DIN but the opening is about an inch wider than Double DIN. Spacer brackets are readily available to fill the gaps. But if you want a factory looking install, seek out a 200mm model. There aren't many but here are some:
https://www.fasmoto.com/ICE/head-unit/head-unit-200mm
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
jeepmor (06-07-2021)
Old 05-20-2021, 12:28 AM   #4
acro
Drives: GT-86
Are any of the listed options plug and play. if not where would i get a harness to install it?
acro is offline   Reply With Quote
Old 05-20-2021, 12:18 PM   #5
LimitedSlip
I own the Pioneer AVH-ZL5150BT but have no experience with any of the other models listed. Here is an extensive thread regarding the install of the Pioneer with much wiring information:
http://www.ft86club.com/forums/showthread.php?t=128548
The AVH-ZL5150BT was not plug and play as shipped but an adapter harness is available here that is pretty good:
https://autoharnesshouse.com
Crutchfield is also known for providing good plug and play adapters:
There are Android based head units that seem to be quite good and plug and play as well but they are generally only available directly from China which is an adventure in itself.
acro (05-20-2021)
aftermarket, double din, recommendation, stereo
Any good stereo systems for an 86? JDMPR725 Electronics | Audio | NAV | Infotainment 21 04-07-2021 02:00 PM
Custom dash for double din stereo. Eman Electronics | Audio | NAV | Infotainment 3 01-17-2017 12:55 AM
Any good stereo installers in NY area that have worked on the frs? mikeg7827 NY / NJ / CT / PA 18 09-09-2013 11:07 PM
aftermarket touchscreen stereo that scrolls sofrsnsokleen Electronics | Audio | NAV | Infotainment 1 09-25-2012 12:19 PM
Good double DIN head units YW-Slayer Electronics | Audio | NAV | Infotainment 3 07-21-2012 11:57 PM
