Old 04-17-2021, 01:30 PM   #1
doug1234
doug1234's Avatar
Drives: 2017 BRZ w/pp
Need advise on tire wear.
I normally was running the tires at a hot temp of 33 degrees; but when on the Shenandoah Circuit at Summit Point WV I notice that I was getting a lot of rollover on the front tires. I talked to an instructor and he advised me to increase the temp to 36-38 Hot. So I did and ran a couple laps and the rolling problem seemed to be gone. I used a friends pyrometer and measured the temps after the next session and the temps where within a couple of degrees inner being hotter and outer being the coolest.
A couple weeks later I drove 8 25 minutes sessions on the Summit Point Main Circuit and noticed that the outer edge was being worn at a lot high rate than the inner. Especially the front drivers. Any advice on the correct setup?
2017 BRZ w/PP
Suspension: CSG Tein Flex A coilovers and SPL Rear Lower Control Arm
Wheels: Apex arc 8 17x9 et42
Tires: 245/40R17 Maxxis VR1 S2
Pads: CSG C1 front and Project Mu Club Racer Rear
-- Alignment:
Corner Balanced
Camber: -2.5 Front; -2.0 Rear
Toe: -0.02 Front; 0.12 Rear
Caster: 5.8 Front
Steer Ahead: 0.0
Thrust Angle: -0.01
--Tire Pressure and Pyrometer readings
Longacre 52-50635 AccuTech Economy Pyrometer
All readings taken after a cool down lap and the long drive to the paddock.
Reading directions: FD->FP->RP->RD
Hot PSI; Outer/Middle/Inner Temps
Session 1:
FD: 39; 113/119/125 FP: 38; 109/119/124
RD: 38; 100/108/109 RP: 37; 90/100/111
Session 2:
FD: 38; 128/129/133 FP: 37; 99/111/108
RD: 37; 96/106/106 RP: 37; 82/92/93
lower FP PSI by 1 deg
Session 3:
FD: 40; 130/140/132 FP: 37; 100/112/117
RD: 38; 101/110/111 RP: 37; 93/103/109
lowered FD PSI by 2 degrees
doug1234 is offline   Reply With Quote
The Following User Says Thank You to doug1234 For This Useful Post:
SCFD (04-18-2021)
Old 04-17-2021, 03:30 PM   #2
ROADRACER
Drives: unlimited cheap build N/A track car
I would add another degree of negative camber. That will probably do it. You will also get some added grip.
ROADRACER is offline   Reply With Quote
The Following 2 Users Say Thank You to ROADRACER For This Useful Post:
doug1234 (04-17-2021), ZDan (04-18-2021)
Old 04-17-2021, 03:37 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
More front camber, -3.5 to -4.5 likely much happier, rear could probably go up a touch as well, -2.5 to -3.0
This is where pyro can be very misleading, heat by the time you get back to the pits doesn't reflect where you're using the most tire which is clearly the outside edge. Adjusting for wear pattern should supersede the pyro readings unless you're getting realtime data.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Old 04-17-2021, 06:23 PM   #4
gatorac
Chin Track Event Manager
Drives: 15 Series Blue
More front camber will help. I used to do 2 events (4 days) and have the tire rotated on the wheel. Then I could run another 4 days. That was with NT01's. Even at 3.5* they would still need to be rotated. 3.5* would also eat up the inside shoulder of my street tires. It's one of the compromises of this strut suspension. No camber gain in a corner like an unequal A arm set up.
Jim Pomroy Chin Track Days Event Manager.
15 Series Blue in white
18 Golf R
09 Comp Yellow NC
20 Gladiator tow vehicle.
gatorac is offline   Reply With Quote
The Following 2 Users Say Thank You to gatorac For This Useful Post:
Old 04-17-2021, 06:42 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ditto ^^^
Moar front camber. Like -3 minimum, preferably -3.5 to -4
Old 04-18-2021, 02:54 AM   #6
jflogerzi
jflogerzi's Avatar
Question for those with more than -3 up front? You using camber plates + crash bolts?
2013 Series 10 FRS #553
Old 04-18-2021, 04:15 AM   #7
strat61caster
Yes, but some (most? Idk) camber plates can hit low -3.x alone, every setup is a little different.
Many aftermarket struts are slotted for more adjustability.
ineedyourdiddly
jflogerzi (04-18-2021)
Old 04-18-2021, 08:49 AM   #8
doug1234
doug1234's Avatar
Thanks for advice. I'm going to flip the tires and ask the shop to put as much negative camber up to -3.5 front and -3 rear. I'm not sure if my camber plates can get to -3.5 maybe I can get -3.
Sent from my Pixel 2 XL using Tapatalk
SCFD (04-18-2021)
Old 04-18-2021, 11:09 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Just Raceseng camber plates. Car is lowered 1.25" on Swift SpecR springs, with Bilstein B8 struts/shocks.
Old 04-18-2021, 11:20 AM   #10
jflogerzi
jflogerzi's Avatar
I am new to coils and camber plates. Just got my new RCE SS-1 put onto the car. Still dialing in ride height. They mentioned -3.5 is possible on a 30mm drop but they recommend -3 and a 25mm drop. Is there any advantage to or a big difference between -3 and -3.5? My car is also still my daily on sx2 rubber
Old 04-18-2021, 11:26 AM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
-3 should be OK. For me, -3.5 is the sweet spot for track/street, others say -4 or even more is better for the track. -3 is a decent improvement over -2.5 for sure, but I say if you can get -3.5 go for it.
Old 04-18-2021, 11:58 AM   #12
jflogerzi
jflogerzi's Avatar
Maybe I will try for 3.2 up front. What are you running in the rear?
Old 04-18-2021, 12:15 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
-2.8, just from lowering 1.25" (stock/factory LCAs). Rear camber isn't as important anyway, anything from -2 to -3 I wouldn't worry about it if you don't have adjustability.
Old 04-18-2021, 12:35 PM   #14
Petah78
Drives: 2022 BRZ sport-tech
With front camber @ 3.5, what is tire wear like for a mostly street driven car with 2 to 3 days of track a year?
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ
Current: 22 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
How does my tire wear look? R_E_L Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2018 08:34 AM
tire wear oppiee Tracking / Autocross / HPDE / Drifting 9 08-29-2017 01:55 PM
Tire Wear? Flo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-10-2017 04:19 PM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 12:31 PM
Let's Discuss Tire Wear SkitterSkotter Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-15-2014 12:35 AM
