Old 01-25-2020, 01:20 AM   #1
sroby
Drives: 2015 Firestorm 08/05/15
Part number for brembo rotors on oem performance package
I’m looking for the part numbers for the oem brembo performance package rotors front and rear. So I don’t have to pay the ridiculous prices from the stealership
Trying to avoid the dual drilled Sti rotors if possible , I want to keep the parking break. I would appreciate it. Steve
sroby is offline   Reply With Quote
Old 01-25-2020, 11:28 PM   #2
sroby
Double post I’m an idiot. ��
Old 01-26-2020, 03:28 PM   #3
Stomachbuzz
Drives: 2013 FRS
Can you not just get the part numbers from the dealer?
In this scenario, I usually try to hunt down a good online OEM parts schematic website. Most dealer websites are absolute garbage in terms of schematics, but occasionally you find one that's bearable.
Stomachbuzz is offline   Reply With Quote
The Following User Says Thank You to Stomachbuzz For This Useful Post:
sroby (01-26-2020)
Old 01-26-2020, 10:39 PM   #4
sroby
Stomachbuzz, yea I’ve got with the dealers both Subie and Toyota, theres just list there part numbers. I tried reverse engineering from the dealer numbers to brembo, nothing comes up. Was hopping somebody had a spare set and could possibly see if there’s a brembo number on them. Pretty sure the front matches the Sti,s. But the rears I believe are the mystery, would like to not have a dual drilled 5x100 , 5 x 114 on the rear. I believe the Frs/86/Brz use a different rotor because of the rear parking brake.
When you call brembo and inquire they differ you to the dealer for the performance package brake inquiries. I guess it’s classified and my T. S. Security clearance I had in the military isn’t strong enough ��. I’ll keep researching thx partner.
Old 01-26-2020, 11:19 PM   #5
NaturallyAspirated
NaturallyAspirated's Avatar
Drives: 2019 BRZ w/ PP
Are you looking for the Brembo manufactured rotors for the Performance Package or are you willing to go with other manufacturers?
I looked for replacement rotors on Rock Auto and it seems like Centric make the rotors you need. These are the ones with the black (coated) center hat section.
Front: 12547019
Rear: 12547043
The parts in the pic below was found in the 2018 BRZ model year under the Brake --> Rotor section.
Once you find these parts on the side, you can click on the part number and it shows other applications these rotors would be compatible with. Since we know the front rotors are the same as the 2004 STi (5x100), it's listed:
But since we know the rear rotors are probably different than the 2004 STi, it's not listed in the applications list for the rears for this part. Only the BRZ and 86 (with TRD package I'm assuming) is shown:
Hope this helps! For what it's worth, Centric makes great rotors. I used to use them on my old track car, as do many others across all makes/models.
NaturallyAspirated is offline   Reply With Quote
The Following 2 Users Say Thank You to NaturallyAspirated For This Useful Post:
sroby (01-27-2020), YamahaR86 (01-30-2020)
Old 01-27-2020, 04:28 AM   #6
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
I second this. When I was a service manager at Firestone these were great rotors!
Drifter X is offline   Reply With Quote
The Following 2 Users Say Thank You to Drifter X For This Useful Post:
Old 01-27-2020, 02:39 PM   #7
sroby
Naturally aspirated appreciate the update partner we can add to our parts historical intel.
Old 01-27-2020, 02:46 PM   #8
sroby
I have been busy, we now have good part numbers from NaturallyAspirated on sourced alternative performance package rotors. Secondly I was able this morning to head down to Douglasville Ga to cyberparts.com ,their salvage yard of all things Frs/86/BRZ. Max is awesome. They had a set of performance package Brembos on the shelf. I have the exact brembo part numbers for the fronts and rears if anybody needs them.
Front PP rotor numbers is. F7B0 35 17XAL052 Brembo
Rear PP rotor number is. R7BPO 35 17XBC209 Brembo
Like all things brembo It’s a top secret clearance issue Ha, but I’m gonna try and cross reference them over to Brembo USA stores numbers. For those who want Brembo oem rotors.
Old 01-27-2020, 03:10 PM   #9
sroby
Now if We could only come up with some torque numbers on the caliper halves. I’ve read all the research I know there not suppose to be separated, and that from Brembo they are assembled under presure and torqued, and that you have to make sure not to loose the crossover small O-rings. According to Brembo they are throw always to which I say Nonsense. These units are painted and powder coated routinely, I understand the Issues of liability. I have worked more than half of my life in and around aircraft maintenance and replacing brake components on F-15,s and C-130 replacing caliper halves and torque values are utmost important. I’ve got a torque value sheet from Fastenall and have come up with some, however I’m still putting this out there for anybody that has done these completely rebuilt what values you have come up with so as to compare what the PCA guysand gals have used. Once again thanks for those who have contributed to the info. Steve
Old 01-30-2020, 02:30 AM   #10
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
There are a few old threads on this topic already.
TL;DR: OEM Brembo replacement parts are very expensive and probably not worth the money.
But if you really want, the part numbers are:
  • 26300FE001 OEM rotor front (single)
  • 26700CA000 OEM rotor rear (single)
  • 26296FE100 OEM pads front (4 pads)
  • 26696FG000 OEM pads rear (4 pads)
Replacement options for rotors are:
  • Centric 125.47019 front
  • Centric 125.47043 rear
  • DBA 4654S-10 front
  • DBA 42656S-10 rear
Replacement options for pads are:
  • CSG.C1.1001.15 front
  • CSG.C1.1539.18 rear
  • CSG.C2.1001.15 front
  • CSG.C2.961.14 rear
  • CSG.CE2.1001.15 front
  • CSG.CX1.1001.15 front
  • CSG.CE1.961.14 rear
  • Hawk HPS HB453F.585 front
  • Hawk HPS HB180F.560 rear
The Following 3 Users Say Thank You to timurrrr For This Useful Post:
86MLR (01-30-2020), LSK (05-12-2021), sroby (02-04-2020)
Old 01-30-2020, 03:03 PM   #11
NaturallyAspirated
TL;DR: OEM Brembos are very expensive and probably not worth the money.
A decent replacement is DBA 4654S-10 front, DBA 42656S-10 rear.
Also, Centric rotors [please share exact model numbers for Centrics if you know].
Centric part numbers were mentioned a few posts before:
Front: 12547019
Rear: 12547043
The Following 3 Users Say Thank You to NaturallyAspirated For This Useful Post:
sroby (02-07-2020), timurrrr (01-30-2020), wparsons (01-30-2020)
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 10:36 AM
FT86SF's Performance Package Brembo Info Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 08-13-2019 05:11 AM
Will The Brembo BBK of the Performance Package BRZ fit into the wheels of Series Blue DaJo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 09-25-2018 06:12 PM
2017 BRZ performance package wheels - part number? willimusk Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-01-2018 04:30 PM
Brembo STI Fronts w/DBA T3 Rotors blueap2 Brakes, Suspension, Chassis 7 06-14-2016 05:36 PM
