Old 08-14-2022, 04:19 AM   #1
moataze
moataze's Avatar
Drives: GT86 2015 GTX (Manual Transmission)
Unhappy Clunking sound over bumpy roads, mechanics are clueless
Hi,
A few months ago I hit a pothole at quite a high speed, right after the incident there was intense vibration from the car and the steering wheel went soft. The car stabilized after 10 -15 seconds but since then I've been having this clunking sound when I steer the wheel, apply the brakes, or drive over bumpy roads.
https://www.youtube.com/shorts/SARgvsJ0kaQ
Mechanics recommended changing the suspension back to stock but to no avail. Any body experienced this issue before?
moataze is offline   Reply With Quote
Old 08-14-2022, 09:13 AM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
In video form, that does not sound like it's coming from under the car. Suspension clunks will typically resonate in the chassis and sound much deeper, that clanking sounds like it's coming from inside the car, or at the very least hitting right at the sheet metal of the passenger compartment.
If it were me I'd stretch my arm under the dash and check the steering shaft. Might be play at the power steering unit or at the rack input shaft, or you might have sheared one of the bolts mounting the rack to the subframe.
Also, just because it's easy, check the strut bars under the hood, if the hit was hard enough, one of those could be popping at the mounting points, and those pops would go up the rod and into the firewall like a speaker.
The Following User Says Thank You to RZNT4R For This Useful Post:
humfrz (08-15-2022)
Old 08-14-2022, 10:12 AM   #3
moataze
moataze's Avatar
Thanks a lot, I will get the steering checked and report back with the findings.
Old 08-14-2022, 12:21 PM   #4
gcmak
gcmak's Avatar
Drives: GR86
Sounds to me like its inside the cabin too - like you knocked some panel or trim piece out of place. Might go around the cabin from ceiling to the floor banging on every piece of plastic you can see - in addition to inspecting steering components since something could have gone out of whack with a really hard hit.
gcmak is offline   Reply With Quote
Old 08-15-2022, 03:06 AM   #5
I'd suggest you check the front wheel bearings and front brake calipers.
The last time I heard something like that, it was coming from an empty, steel wheeled, hay wagon being pulled down a washboard lane.
humfrz is online now   Reply With Quote
Opie (08-30-2022), spcmafia (08-15-2022)
Old 08-15-2022, 09:04 AM   #6
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I've had bolts come lose and absolutely drive me nuts around the dash. Might be worth pulling the tweeter speaker panel off and checking the screws.
Old 08-15-2022, 11:48 AM   #7
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I also think it is the wheel bearings. It either sounds like there's metal grinding while on the highway, or a clunking noise whenever turning-going over small bumps.
spcmafia is offline   Reply With Quote
The Following User Says Thank You to spcmafia For This Useful Post:
Opie (08-30-2022)
Old 08-15-2022, 01:48 PM   #8
radroach
Drives: car
All the above comments, lol you guys should try better to stay current with the issues on these cars. This issue has been covered multiple times and should be well-known by now!
It's the electric power steering coupler. It makes corrections over bumps and rough pavement, and rattles if it has a broken part. The power steering behind your steering wheel has a worn or shredded bushing, a $20 replacement part.
Here's the repair procedure for the 86 / FR-S / BRZ EPS electric power steering coupler:
https://www.ft86club.com/forums/showthread.php?t=133606
The Following 2 Users Say Thank You to radroach For This Useful Post:
humfrz (08-15-2022), Wally86 (08-18-2022)
Old 08-15-2022, 03:58 PM   #9
Easy for you to say, you still have short term memory -
norcalpb (08-15-2022), soundman98 (08-15-2022)
Old 08-15-2022, 11:41 PM   #10
soundman98
ProCrastinationConsultant
soundman98's Avatar
stay current, i'm still trying to catch up to the past!
humfrz (08-16-2022)
Old 08-16-2022, 02:25 AM   #11
Yep, I hear that and I got a long way to catch up -
"hang on, I'm ah reachen fer the road gear" -
soundman98 (08-16-2022)
Old 08-25-2022, 08:18 AM   #12
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
possibly the electric poer steering steering damper\coupler
part is like $5 but about 2 hours of fun to install
think there is some youtube videos on replacent as well
AussieBRZ is offline   Reply With Quote
Old 08-27-2022, 05:19 AM   #13
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Hope it's not this... (This is a joke of course.)
Skip to 0:48
The Following User Says Thank You to x808drifter For This Useful Post:
blsfrs (08-27-2022)
clunking, issue, steering
Rear Clunking Sound. Help! Trev6450w Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-06-2021 10:36 AM
Clunking Sound from Steering Related Parts MCTeeJ Issues | Warranty | Recalls / TSB 2 02-27-2020 05:40 PM
Clunking sound after coilover install Dee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-22-2018 05:12 PM
Clunking sound coming from suspension Maverickgear Issues | Warranty | Recalls / TSB 9 07-11-2014 03:41 PM
Neutral to 1st clunking sound wallace03 Issues | Warranty | Recalls / TSB 3 01-10-2013 10:50 PM
