CANADA Canada
Old 11-26-2012, 12:17 AM   #1
Smilez
Drives: BRZ WRB Sport-tech
Trunk release failure - BRZ
Interior trunk release switch under the steering wheel has no effect. Exterior switch on the trunk lid has no effect. Button on remote doesn't work.
Mechanical key does work.
Valet trunk disable is NOT engaged. Tried it both on and off.
Has anyone else encountered this issue? A search on this forum didn't show any others. I've had the car 2 weeks, 1350kms. All methods of opening the trunk worked fine until today.
Thanks!
Stephanie
Smilez is offline   Reply With Quote
Old 11-26-2012, 01:28 AM   #2
Dimman
Kuruma Otaku
Dimman's Avatar
I have vague memories of someone having trunk release issues...
Was it @bneale ?
Because titanium.
Old 11-26-2012, 02:03 AM   #3
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Thanks!
Stephanie
Weird... Have you tried pulling on the Emergency escape cable under the trunk lid? If that works and the mechanical key works... Probably an electrical problem.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-26-2012, 10:10 AM   #4
NYNOMAD
Drives: BRZ WRB LTD MAN
I have had this happen when I really load up the trunk. Once I take all the stuff out it is fine again.
NYNOMAD is offline   Reply With Quote
Old 11-26-2012, 01:19 PM   #5
Smilez
hmm, never had more than 2 bags of groceries in it. Probably just a simple electrical fault. Time to test out Docksteader's famous service department.
Old 11-26-2012, 01:31 PM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
Report back to us how it went! Make sure you mention about the rough idle as I have done so, just so they're aware.
Hopefully the service manager sees this as a common problem and start thinking about what to do.
2000 MR-S 5MT
2010-2012
Old 03-29-2013, 02:49 PM   #7
Newguyottawa
Drives: Brz black
I just had a problem with trunk. The car was unlocked and the internal trunk release button and the physical trunk handle both failed to open the trunk. However, the trunk opener on the remote control key fob worked. Once the trunk was opened, i haven't seen the issue again.
Newguyottawa is offline   Reply With Quote
Old 03-31-2013, 09:40 PM   #8
narfy
short asian guy
narfy's Avatar
Drives: ZN6, VZN185
is there an electronic trunk release lock button on the left side of the trunk liek there is on an FRS?
VZN185 - 32" BFG AT, OME suspension, ARB bumper, lightforce lights, TRD trans cooler, TRD exhaust, budbuilt plates...
ZN6 - stock with HIDs and LEDs...
fng@regencyauto.com
narfy is offline   Reply With Quote
Old 03-31-2013, 09:43 PM   #9
Newguyottawa
Drives: Brz black
There is.
Old 04-01-2013, 09:06 AM   #10
wparsons
wparsons's Avatar
That wouldn't prevent the key from mechanically opening it though.
There's no way to get into the trunk from the interior without taking the back seat apart, so the glow in the dark emergency release isn't so helpful in this case.
flickr
Old 04-02-2013, 07:49 PM   #11
narfy
short asian guy
narfy's Avatar
Drives: ZN6, VZN185
the OP can use her key to open the trunk... but no electronic trunk release function works... which leads me to have her check the button first...
as for wparsons/newguyottawa, you would have to open the trunk once to figure out why your latch isn't working... usually the key cylinder will work regardless of wiring/electronic issues... only problems would be if it's been apart before and not reassembled properly... or the latch or key cylinder are hooped...
fng@regencyauto.com
Old 04-16-2015, 06:25 PM   #12
Raven_FR-S
Raven_FR-S's Avatar
Drives: 13 Scion FRS
fix for mine.
I was reading this thread then walked out to the car after calling the dealership...I was told that we have a small key port under the edge of the lid that was for our key...I had no idea it was even there. But I opened it up just to find that the oil jug i had in the trunk had hit the trunk cancel button not allowing me to open it up. Pushed the button back in and no more problems opening it up. My mistake. I'm an idiot. I guess I should stop taking hard turns with stuff in the trunk lol.
Add me on IG @CNastySon
Mishimoto..."Do Yo Temps Stay Low, With the Throttle To Da Flo!!!
Raven_FR-S is offline   Reply With Quote
Old 04-16-2015, 06:51 PM   #13
mrdanyo
Drives: 2014 BRZ Limited (World Rally Blue)
This happened to me before. It doesn't stop your key from working, although I thought it did too. You have have to turn it harder which I was afraid of doing because I didn't want to break anything.
I turned harder using both hands and it opened. Then I released the oddly placed trunk lock feature on the left side.
mrdanyo is offline   Reply With Quote
Old 04-16-2015, 10:19 PM   #14
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
It doesn't help that the key is a tiny little nub that is hard to apply force to...
If the key turns but the trunk doesn't open, then it might not be the valet-disable switch...
daiheadjai is offline   Reply With Quote
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 12:25 PM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 06:07 PM
BRZ Limited Electronic Trunk Release diirk Electronics | Audio | NAV | Infotainment 4 09-17-2012 12:42 PM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 01:25 PM
A pessimist's take on sales success / failure Mess11 Scion FR-S / Toyota 86 GT86 General Forum 137 11-24-2011 02:10 PM
