Old 07-06-2019, 04:49 AM   #1
kev0
Drives: '14
Lit symbols in dashboard after flashing Xero Limit tune
Flashed the base tune from Xero-Limit running. Car had trouble starting up. Engine turns over but RPM’s go down to like, 0. Engines dead quiet. I have to give it steady gas for about 10 seconds to keep it alive and it will eventually stay alive but my idle RPMs are around 400-600. My ABS (C1288) and ECM (P0171) codes are on. My oil pressure lamp flickers on faintly and sometimes remain on.
My ABS and Traction Control lights are on as well. None of these lights were on before installing my Supercharger. Car drives fine even though dash is lit like the Vegas strip.
Is this meant to happen due to the base tune or is something seriously messed up with my car?
Besides the SC install (Sprintex 210), I also had a Flex fuel kit installed. My installer used the rear o2 sensor from my catless header with the flex fuel kit.
https://datazap.me/u/kev0/base-tune?log=0&data=3-21
kev0 is offline   Reply With Quote
Old 07-06-2019, 05:29 AM   #2
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
it's messed up. Probably the tuner doesn't care about doing it right.
why? is offline   Reply With Quote
Old 07-06-2019, 05:50 AM   #3
secho
secho's Avatar
Drives: GT86, forged and supercharged
Boost leak? You have got super-positive fuel trims. Port injectors are OEM? What about MAP? 3bars? Was the callibration changed to suite?
secho is offline   Reply With Quote
The Following User Says Thank You to secho For This Useful Post:
kev0 (07-06-2019)
Old 07-06-2019, 06:02 AM   #4
kev0
Drives: '14
I hope that's not the case.. spent $850 on the tune including the ecutek cable and license.
Stock PI, MAP. Not sure about the callibration, I'd assume that is my tuner's job.
The brake pedal feels soooo hard to press down.. Not sure if that's tune related.
Old 07-06-2019, 06:07 AM   #5
tomm.brz
Drives: brz 2017 hksv2
not tune related
your installer did a mess, around brake booster also
kev0 (07-06-2019)
Old 07-06-2019, 06:09 AM   #6
secho
secho's Avatar
If brake pedal is hard to press = incorrectly connected vacuum hose. Check if your brake vacuum hose is connected after throttle body. Then, FA20 engine has two crank ventilation ports, one with pcv valve, should be connected after throttle body to intake manifold as well for high vacuum, and low vacuum ventilation is before the trottle body. If you have it misaligned or wrongly connected you might have vacuum leak somewhere causing you engine is running very lean and fueltrims are maxed.
kev0 (07-06-2019)
Old 07-06-2019, 06:21 AM   #7
kev0
Drives: '14
Thank you sir. Could misaligned hoses also cause the P0171 code?
Old 07-06-2019, 07:50 AM   #8
secho
secho's Avatar
P0171 meens too lean.. so, it is possible consequence.
Old 07-06-2019, 12:00 PM   #9
86TOYO2k17
Drives: 2017 toyota 86
You have like 10 different threads created over your messed up install. With people just repeating the same things over and over for you to check and fix. It’s essentially just a manifold swap not that many things to check or that could go wrong. If you haven’t resolved this yet then honestly at this point tow it to a reputable shop and have them reinstall/fix it instead of having your friend install it before you do irreversible permanent damage to your car.
The Following 5 Users Say Thank You to 86TOYO2k17 For This Useful Post:
Icecreamtruk (07-07-2019), kev0 (07-06-2019), soundman98 (07-06-2019), Tcoat (07-06-2019), tomm.brz (07-06-2019)
Old 07-06-2019, 03:53 PM   #10
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Remember when I said to always buy new?
And when you buy used you'll always buy someone else's headache?
Good luck, I hope you get it fixed.
The Following User Says Thank You to Mr.ac For This Useful Post:
kev0 (07-06-2019)
Old 07-06-2019, 05:48 PM   #11
kev0
Drives: '14
Yeah that's true, but installer's my buddy and I wanted to pay and support my buddy than a shop, but I've learned my lesson.
Yes, I remember, but the SC kit itself has no problems. Just ran into some problems after the installation.
Old 07-06-2019, 06:08 PM   #12
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
More than "just running into problems" when you have to make so many threads about your botched install. If you have money take it to a reputable shop now and get it fixed and a proper tune created. You're working with someone that's clueless.
Old 07-06-2019, 06:23 PM   #13
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Not yet *knock on wook* hopefully I wish I can be proven wrong.
Good luck buddy.
Old 07-06-2019, 10:40 PM   #14
soundman98
ProCrastinationConsultant
soundman98's Avatar
This is the problem with involving family/friends in your own hobbies. Now you gave him a chance, he screwed up, give it to someone who knows what they're doing. If he's a good guy, he'll own up to it and learn, if he's a petulant child, he'll blame you for the entire ordeal.
Xero Limit - Tune & Flex Fuel Updates! Xero-Limit Software Tuning 12 11-20-2019 12:17 PM
FS: BRAND NEW Moto-East/Xero-Limit Flex Fuel Kit - SOLD! J1Avs Engine, Exhaust, Bolt-Ons 7 02-14-2019 07:02 PM
Xero Limit Introductory Specials! Xero-Limit Announcements, Contests, Giveaways 1 11-23-2018 01:23 PM
After flashing A new tune to your car John27 Software Tuning 5 06-08-2018 03:03 PM
Indicator Symbols issue dejahboi Electronics | Audio | NAV | Infotainment 0 02-01-2017 03:59 AM
